Old 09-23-2009, 06:32 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
Bully Clutch, anyone heard of it or use it?
Im looking into getting a Stage 3 sprung loaded clutch from Bully. Its a big canadian company located right here in Ottawa. They are well known in the import scene (rice rockets) Just wanted to know if anyone has ever installed them in their car?
violametallic-S- is offline   Reply With Quote
Old 09-24-2009, 03:03 AM   #2
dbw
link
Would you post a link to it please?
I'm in Wpg.
dbw is offline   Reply With Quote
Old 09-24-2009, 03:22 PM   #3
2001 RUF 3800S
bullyclutch.com
Might be getting the Stage 3 sprung clutch. 1000cdn.
Old 09-24-2009, 03:54 PM   #4
ChrisZang's Avatar
Quote: "... recommended for racing or forced induction ..."
Unless you really want to RACE or have turbo or super charger I don't think you will be too happy with that clutch
Ever driven a race clutch in stop and go?
Old 09-24-2009, 07:53 PM   #5
The various definitions of "stages" differ from company to company, but generally, a stage 3 clutch isn't going to be terribly streetable. Further, as a more known entity for a Porsche application, I would lean toward SPEC.
Boxster S
Old 09-24-2009, 08:04 PM   #6
2001 RUF 3800S
Ive driven cars with Stage 3 clutches, not too bad. Its not a daily driver so I wont get too annoyed of the stiffness. And Yes I will be turbocharging it in the spring, or supercharge it not sure yet.
Old 09-25-2009, 05:22 AM   #7
JAAY's Avatar
Why do you want to go with a non-oem clutch? I looked into these options also when I did my motor swap and the best info that I received was to use a cayman clutch. That is what I have in the car now and it is great and holds the power no problem. My .02
JAAY is offline   Reply With Quote
Old 09-25-2009, 05:49 AM   #8
2001 RUF 3800S
I'm on my second oem clutch and it's giving out already. Why not get a performance clutch for a few hundred more that can tolerate abuse better then the oem. I'm getting some type of forced induction so I want the power to go to the ground. Stage 3 is rated for 500 hp and it's made for the track. So it will last forever on the street
Old 09-25-2009, 05:57 AM   #9
Send a message via AIM to blinkwatt
The cayman clutch you say? Is there a difference between the cayman clutch and the 987? I thought the car were almost identical mechanically?
Would a cayman S clutch kit be a straight swap on a rear wheels drive M96 6-spd tranny?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 09-25-2009, 06:27 AM   #10
JAAY's Avatar
Todd turned me on to the idea. I used a 5speed cayman clutch because that is what I have. It fit perfect. I would imagine that a cayman S 6speed clutch would be the same also. It comes down to spline count and the flywheel I believe. Ask Todd he will know. He knows everything!
Old 09-25-2009, 12:14 PM   #11
ChrisZang's Avatar
so for my own curiosity?
Can it generally be said that a race clutch will last longer than a OEM clutch?
Old 09-25-2009, 02:25 PM   #12
No, you can't say that for sure, it depends on the specific design of the clutch in question. A light weight ( small diameter,low Inertia) "road race" clutch could be destroyed quickly with a drag race style launch.
