Old 08-25-2009, 09:18 PM   #1
boxster cluster freeze
The cluster will intermittently freeze or switch randomly from mph to km. Previous owner took it to the dealer where he got a quote of $1,500 to fix it. Old owner took a pass but now I want to fix it.
Is it as simple as swapping out the cluster? Should I just take it out and inspect it for a loose wire. (It will work if you tap the top of the cluster..like an old TV fix.) and then if nothing obvious just swap it out with a like model used cluster?
urban_legend is offline   Reply With Quote
Old 08-26-2009, 12:40 AM   #2
Lil bastard's Avatar
You can pull the display, disassemble it and look for breaks in the solder or dirt which shorts the circuits.
If it doesn't work, you can source a used display from LA Porsche or other wrecker and go to a dealer or indy w/ a PST2 or PIWIS to set the actual mileage (no reputable co. will reset it to a lower mileage).
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 08-27-2009, 07:45 AM   #3
I'll see you mine for 100 shipped, just PM me
BoxsterLewis is offline   Reply With Quote
Old 08-27-2009, 07:15 PM   #4
Compatibility?
I have a 2001 - what cluster(s) will be compatible?
Part number or year/model?
Lots of them floating around - in great condition even in the worst wrecks.
