boxster cluster freeze
The cluster will intermittently freeze or switch randomly from mph to km. Previous owner took it to the dealer where he got a quote of $1,500 to fix it. Old owner took a pass but now I want to fix it.
Is it as simple as swapping out the cluster? Should I just take it out and inspect it for a loose wire. (It will work if you tap the top of the cluster..like an old TV fix.) and then if nothing obvious just swap it out with a like model used cluster?
