Old 08-15-2009, 06:43 PM   #1
Check engine light then smoke...
Ok need some opinins on this one but I'm hoping it's nothing too bad. I was drving and came to a red light look down at the dash and se th check engine light on. Solid and not blinking so I wasn't too worried. Drove about another mile and got to a buddies house so I decided to turn the car off to see if it'll go away. As soon as I turn off the engine and hear like a rush of air or liquid flowing. I'm like ok maybe ac compressor. I turn key to crank and wait for countdown and he oil levels is Dan to nothing. Get out of the far and check the oil level with the dipstick and it's ok. No coolant smell or white residue in the oil. Open the coolant tank still full and looking nice and orange. Get in the car and a puff large puff of smoke comes out. Turn it off and try again another large puff of smoke. No noise of metal rattling bust a u turn and still no prblem with the engine. Turn it off and try to start if again and puff page smoke with no rattling. Engine sounds fine. I'm thinking the AOS just took a crap and if it's done doesn't hold pressure in the oil system therefore showing the low oil level. No oil dump. Temperature is normal. What u guys think..
mikes_box is offline   Reply With Quote
Old 08-15-2009, 06:58 PM   #2
sounds exactly like what happened with my car 5 months ago. but no CEL.
white smoke - crop duster like. coolant and oil both OK. engine starts and idles OK, no abnormal noise, etc
got advise from this forum, AOS replaced. had lost 1 qt.
sb01box is offline   Reply With Quote
Old 08-15-2009, 11:24 PM   #3
pulled the code reader up and came up with two codes... p1128 and p1130... any input...
Old 08-16-2009, 10:08 AM   #4
Check out this thread for those codes
Advice for CEL coded P1128 & P1130
boxster7614 is offline   Reply With Quote
Old 08-16-2009, 10:10 AM   #5
if I am not mistaken, these are the front two o2 sensor fault. most likely due to excessive oil on the sensor.
there are may topic on smoke as it relates of AOS. if you search on smoke or aos you will find wealth of information. just need to go over it as it pertains to your car.
I recall that if it is AOS, then
not taking care of it may damage your O2 sensor and catalytic converter.
good luck
Old 08-18-2009, 02:31 AM   #6
TEX
Smile same problem
Thats IT!!
ITS the AOS , I had smae problem lots of white smoke on acceleration up a ramp and on start up.
Get the AOS replaced quick smart.
good luck
TEX is offline   Reply With Quote
