Old 08-12-2009, 04:31 PM   #1
Coolant spewed everywhere!
So i'm at a light and i see white smoke, i pull in a parking lot and there it is gushing coolant everywhere from the engine bay. This car is killing me. I have a 3.6L but i'm sure the coolant hose are probably the same. Could this be like a head gasket or probably a popped off Coolant hose?? Thanks.
BoxsterLewis is offline   Reply With Quote
Old 08-12-2009, 05:33 PM   #2
With as much coolant as you describe it is probably just a split hose.
When head gaskets fail on these engines (a very rare event, as far as I can tell, btw) the coolant tends to leak internally and end up in the oil or combustion chambers.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 08-12-2009, 06:35 PM   #3
Coolant Leak
I had something similar happen. It turned out to be air in the coolant system causing the entire coolant tank to overflow. No repairs were necessary. Some others have had the same thing happen. Good luck!
Take a look at this thread: http://987forum.com/forums/showthread.php?t=21536
SubVet is offline   Reply With Quote
Old 08-12-2009, 07:14 PM   #4
It could be the water pump. my coolant went every where when my went. Also all the lights on my dash lit up because it broke the serpentine belt.
boxster7614 is offline   Reply With Quote
Old 08-12-2009, 07:57 PM   #5
Lil bastard's Avatar
+1 - Waterpump
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 08-13-2009, 04:53 AM   #6
There should be no beer smile after the +1 on the water pump lil bastard lol. I've spent around 26K fixing this car already
My lights did not light up so im hoping it is a spilt hose! I will find out sometime today and come back to you guys.
Old 08-13-2009, 09:04 AM   #7
rdancd816's Avatar
If coolant spewed everywhere it could indeed be the WP. I had an experience where my 986 dumped a ton of coolant near the right rear wheel well. Turned out the only problem was a bad radiator cap.
"97 Boxster" Guards Red, Coppell, TX 36,500 miles
2010 Mazda CX-7 AWD, Turbo, Grand Touring
rdancd816 is offline   Reply With Quote
Old 08-13-2009, 10:34 AM   #8
That's what im hoping, either a cap, cracked hose or tank!!!
