Originally Posted by BoxsterLewis
So i'm at a light and i see white smoke, i pull in a parking lot and there it is gushing coolant everywhere from the engine bay. This car is killing me. I have a 3.6L but i'm sure the coolant hose are probably the same. Could this be like a head gasket or probably a popped off Coolant hose?? Thanks.
With as much coolant as you describe it is probably just a split hose.
When head gaskets fail on these engines (a very rare event, as far as I can tell, btw) the coolant tends to leak internally and end up in the oil or combustion chambers.
