Old 08-06-2009, 08:03 AM   #1
Seatbelt Light On With 6-harness
Í'm currently running aftermarket seats with 6 point seatbelt and i'm having trouble keeping the seatbelt light off. Any suggestions on keepin that light off???
blinkfan is offline   Reply With Quote
Old 08-06-2009, 08:18 AM   #2
ChrisZang's Avatar
did you take the seatbelt receptacle from the original seat and attach it to your aftermarket seat (and plug it into the connector under the seat)?
Old 08-06-2009, 08:20 AM   #3
Did you try jumping the wires that went into the original seatbelt recpticle?
98 Arena Red 986
Old 08-06-2009, 10:03 AM   #4
ok
sounds great I will do that!!!
Old 08-06-2009, 10:29 AM   #5
ChrisZang's Avatar
I am not 100% sure that you can "jump" these wires (meaning directly connecting them to each other). I believe to remember that you need a resistor to connect them but all of this is a bit vague in memory, maybe someone else remembers correctly.
nevertheless for my race seats I picked up two used receptacles on eBay (taking the original ones off the OEM seats is a major pain) and I plug them in when I switch seats. These receptacles pop up on eBay from time to time, they are usually in the $40 ~ $80 range.
This also gives you the added benefit that you can use your 3-way belts to/from the track
Copyright ©2000 - 2024, vBulletin Solutions, Inc.
Copyright 2024 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
