Old 07-28-2009, 04:38 AM   #1
Oil Build up on Pipes - AOS / Throttle Body / MAF
Ive had my ride a 2000 Boxster Semi Auto for about a year now and finally took a look at the engine.
Attached are the two pictures showing oil build up over pipes A and C. Does anyone know if this points to any problem in particular like replacing the AOS or cleaning the throttle body.
The Durametric error codes are as follows;
Error Codes P0102 P0107 P1126 P1133 P0300 P0302
Also is the throttle body shown in the picture labelled D as I will most likely open that up and clean it with CSR CO Contact cleaner which I think is also ok to clean the MAF with? Can anyone confirm that?
00boxster is offline   Reply With Quote
