07-13-2009, 04:11 PM
Replacing 986 headlamps
Hi guys,
I noticed that in the newer models of Porsche Boxsters, the glass/whatever in front of the lightbulbs is more clear (less foggy/plastic looking) than the older models (2003, for example). What is the easiest/most affordable way to replace those headlamps?
Is something like this what I want to use: http://www.************************************************************/product.asp?pf_id=P996.631.036.90&dept_id=4670
I don't really care about the HID/xenon lights, just the clearness/appearance of those. Any suggestions? Thanks guys
Side note: I chose the light bulb post icon for this thread... pretty clever, right? haha
07-13-2009, 04:36 PM
07 Carrera S Cab
No, that kit in your link is an internal modification to your headlamps. It will not clear up the clear plastic casing of the headlamp housing. There's really not much you can do to recover/polish the exterior of the headlamp because there's a coating on there to protect the headlamp from rock chips which you don't really want to remove. The cheapest way to fix that problem is to buy another set of used headlamps that are in better condition than yours.
Originally Posted by kerplunk
Hi guys,
07-13-2009, 09:05 PM
I have a 2003 Porsche Boxster. Correct me if I am wrong, but I thought that 2005 models and beyond have newer, clearer looking headlamps?
Edit: Ohhh, wow. I think I am just wrong. Weird... but don't the newer ones look a little bit different somehow? Sorry
07-14-2009, 03:43 AM
There were headlights of a different design
introduced in the 2005 model year 987. No they don't fit 986 models. Yes they look different as they use a different technique to focus the beam than the earlier ones did.
Classic changes to 986 headlights include de-ambering them or substituting a litronics retrofit kit at $2k+ list from a dealer.
07-14-2009, 07:26 AM
to convert...
Hi guys,
What's needed to convert the older 986 headlights to the ones listed on the automotion web site? I know it's not a plug and play, but how much work/cost is involved in converting to those relatively inexpensive lights?
Cheers
Jon
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
07-14-2009, 08:16 AM
Originally Posted by ekam
That's much more consistent with what I've seen for pricing. I thought it was too good to be true. Luckily the lamps on mine are pretty bright so I don't feel the itch to upgrade too strongly. My paychecks have many other upgrades/maintenance to get done first.
PS, what I'm smoking is good. It's NorCal, baby.
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
07-14-2009, 11:26 AM
Wowwwwwwwww. Expensive. You guys helped clear things up though, thanks!
07-14-2009, 12:56 PM
There is a consistent used litronics market on ebay and various porsche forums. Prices used to average around 1000 - 1200 per pair but as with everything else that has fallen to around 800 or even less in some cases.
2003 Boxster - Sold but not forgotten
07-14-2009, 01:03 PM
i'm guessing there's no way to verify their working order prior to purchase? Do they often break?
Jonny Wonder
Previous Toys:
2005 RX-8, RIP
