Old 07-09-2009, 04:32 AM   #1
Newbe Question
What is the logic on the gas gauge on the boxster. What are the 4 s for?
97 Boxster 115k miles
3 spoke wheel,
OZ Racing Rims
ChefCarnivore is offline   Reply With Quote
Old 07-09-2009, 04:35 AM   #2
2nd question
I forgot to add this. Is there a way to default the air handling to "off" so I don't have to manually set it each time I start the engine?
3 spoke wheel,
OZ Racing Rims
Old 07-09-2009, 08:30 AM   #3
They are fractions, ie 1/4th of a tank.
What do you mean by air handling? If you are talking about the climate control, I just hit the minus button until it says "Off" and it stays that way between restarts.
-james
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 07-10-2009, 10:02 AM   #4
Not mine
I also hit the minus sign but on restart it revert to air conditioning.
Guess you are right about the quarter tank indications. It just looked odd to me.
3 spoke wheel,
OZ Racing Rims
Old 07-10-2009, 12:25 PM   #5
Do you use auto setting? try going to "manuell"(that still cracks me up)
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 07-10-2009, 01:16 PM   #6
Porscheectomy
The 1/4 2/4 3/4 4/4 is a german thing. I've seen it in Mercedes cars too. The thing that's annoying to me is the speed ticks in 25mph increments. I hate that.
I too have to reset the fan to off every time I start the car. There's no way around it.
Old 07-10-2009, 01:34 PM   #7
Mine always remember the previous fan/AC setting.
Old 07-13-2009, 05:01 AM   #8
I have a '99 and it resets on restart as well.
joeyp_boxster is offline   Reply With Quote
Old 07-13-2009, 05:48 AM   #9
tonycarreon's Avatar
you think the 0/4, 2/4, 4/4 is weird, on my old 944 the tachometer was backwards and the gas gauge went to 1/1...
Old 07-13-2009, 08:47 AM   #10
I only picked up my 99 boxster a few weeks ago, but I noticed the same thing on my auto AC controls. If it's set to "off" when I shut off the car, it will come back on to the previously set temp, but with the fan set to zero bars on the vertical scale.
It think that is effectively the same as off, since there is no fan running. Also, from the engine sounds, I'm pretty sure there is no compressor running at that point.
Just my $.02...from another noob
lagrasta is offline   Reply With Quote
Old 07-20-2009, 06:28 AM   #11
Problem solved
Lagrasta,
That is what mine does (on startup it shows last temp and fan off and manual) which I assumed was different than "OFF". :dance:
3 spoke wheel,
OZ Racing Rims
