Old 06-03-2009, 12:03 PM   #1
glass tops
who has had one fitted recently(within the last year) how is it holding up, how much did you pay and please post pics if you can, im looking for a top for my 2000 and whant to know what it will look like on my car as well as who makes the best top cost wise with good reliability as well.
dirtyg is offline   Reply With Quote
Old 06-04-2009, 01:59 AM   #2
Best one to get in my opinion is a factory top with the glass window... Find a used top from a 2003-2004 Boxster, and it's a direct swap for your car.
I did it, and have loved it so much more ever since...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 06-04-2009, 03:20 AM   #3
07 Carrera S Cab
Boxtaboy's Avatar
To clarify, if you go this route, you have to find a top along with the entire metal top frame on which the canvas top fits on, from an 03 or 04 boxster. Just getting the 03 or 04 canvas top (without the frame) like you would by buying an aftermarket glass top would not work on your car since it has the older frame on which the old plastic window top fits on. You would then bolt the entire top along with the frame onto your car, as opposed to just fitting an aftermarket top onto your existing frame.
The best route is to source one of these factory 03 or 04 used top and frames because it gives you the most access to the engine from the service position, but if you can't find one, I think the GAHH aftermarket glass top is a very good alternative, as they are the only ones I know of that offer a lifetime guarantee against the window separating from the canvas- which is due to the extra tension put on the glass as it folds...something that is not an issue in the factory 03 or 04 tops, because the newer frames have a 4th bow to allow a clean fold of the glass window.
I can't tell you how nice it is to not have to stare at your rearview mirror anymore to see if the plastic window would fold right or crack as you're putting down the top, or actually having to get out of the car to chop the top. With the glass top, none of that is a worry anymore, and you'll just love it.
Old 06-04-2009, 05:30 PM   #4
i have been looking around for a complete top best price so far is 2500
Old 06-04-2009, 05:33 PM   #5
[/QUOTE]
your car looks real good is that 10" rubber in the back?
Old 06-04-2009, 06:02 PM   #6
07 Carrera S Cab
Boxtaboy's Avatar
Thanks. The rear wheels are 18 x 9.5.
