Old 04-24-2009, 11:48 AM   #1
Originally Posted by impboy
I have Kuhmos on my '01 Box and had them at the pressure they said on the tire. The car would get loose on hard cornering. When I asked my good friend and mechanic about this, he said to go with the recommendations on the door of the car. His point was that tires are made to work on a variety of cars but that all cars are different. When I switched air pressure to what was on the door, the car handled so much better in hard cornering.
Hey, I'm 49 and I'm still learning something new everyday.
PRESSURES ON THE SIDES OF TIRES ARE MAX PRESSURES FOR THE TIRE NOT THE PRESSURES YOU SHOULD USE!!!! Sorry for yelling but you should not run max pressures. Always run the pressures form the owner's manual. If you have special circumstances adjust them from owner's manual recommendations. But always start with the owner's manual recommendations and go from there.
renzop is offline   Reply With Quote
