Old 04-08-2009, 06:32 AM   #1
edevlin's Avatar
If you have the money, chipping seems to work, I like mine. You just need to determine if an increase in 10hp or so, coupled with a better throttle response is work the cost. In the non-porsche world, most folks would think chipping our cars for modest increases in performance would be a joke. But additional hp is hard to come by in our cars.....
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 04-08-2009, 12:11 PM   #2
Here's a question:
I've swapped my headers and exhaust on my 2.5 and got a bump of 15 hp and 19 ft lbs of torque.
If I chip the motor, will I get another bump?
Man, tweaking a measly 10 hp out of a Porsche motor costs a wad of cash. Something like $100 per horse!
Old 04-08-2009, 01:03 PM   #3
ChrisZang's Avatar
IMHO, if you have all this disposable money then "upgrading" the engine should be the last step.
First upgrade the suspension (coil overs and stronger sway bars) and the driver (AX and DE)
Old 04-08-2009, 02:44 PM   #4
Wingman
Heyjae,
What kind of wing do you have on the back of that car? Does it keep you on the ground?
MidMotor2TrunkToter is offline   Reply With Quote
Old 04-08-2009, 04:17 PM   #5
I keep seeing posts about headers being a good mod for hp increase, which headers are recommended and proven? Any links or suggestions?
http://i240.photobucket.com/albums/f...r/carlit-1.jpg 2003 Boxster S
spyder803 is offline   Reply With Quote
Old 04-08-2009, 04:22 PM   #6
google up fabspeed and take a look around..
eightsandaces is offline   Reply With Quote
Old 04-08-2009, 04:43 PM   #7
Originally Posted by MidMotor2TrunkToter
Heyjae,
It's a universal APR wing. I added spacers to it since that picture was taken, so now it's even higher. The wing more efficient now and I'm starting to get a lot of push on big sweepers, so I added front canards last week to help offset that. I'm excited to see what it'll do when I get on the track again in a couple weeks.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
Old 04-08-2009, 06:06 PM   #8
Not according to some testing
I've been advised of.
The Chinese headers available on eBay are good enough and don't cost an arm and a leg. But beware and use someone with experience in removing frozen bolts as it is easy to break off the bolts that attach the stock headers to the block. Use new bolts and anti-seize when you install the new headers.
This is a case where spending more for a part doesn't get you more performance.
You want to do the flash only after you've done all the intake and exhaust mods you are going to do and you want to do it with access to a dyno so the parameters can be optimized for your specific setup. You'll get a higher rev limit and a quicker response but it is amazing how good the recent Boxster ECU stock settings are. They even work well with enhanced displacement engines.
Old 04-08-2009, 08:04 PM   #9
Perfectlap's Avatar
I did all this on my old Miata. Headers, intake, exhaust, suspension, bla bla bla.
The grumble of the engine on start up was so cool. The suspension was perfect.
Had two sets of wheels, one with r comps for AX and one set for winter.
All for the cost of one Boxster exhaust upgrade and a Tequipment carbon shift knob.
BORN: March 2000 - FINLAND
