Old 04-02-2009, 03:10 PM   #1
when i step on the gas on my boxter nothing happens
i have a 2000 boxter ,i start the car when i press the gas ,it doesnt respond ,the car does not accelerate ,the rpms dont even go up
when i tried the next day it was fine
later on that day it did it again
does anyone know about this problem
please help
chriscornell007 is offline   Reply With Quote
Old 04-02-2009, 04:20 PM   #2
Did you start the car first?
Sorry, I don't know the problem, but felt a wise remark was appropriate.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-02-2009, 04:42 PM   #3
oh, man... i was just gonna throw that one in... hope you get it all figured out..
mikes_box is offline   Reply With Quote
Old 04-03-2009, 08:00 AM   #4
FTD
A sticky throttle body?
I don't even know what a throttle body is, but I too felt like being 'wise'.
It has been discussed here many times so maybe that is a jump start to research?
Old 04-03-2009, 08:29 AM   #5
Look into the TPS, or even the electrical connection at the TPS.
941MXVET is offline   Reply With Quote
Old 04-04-2009, 05:02 AM   #6
Send a message via AIM to dmenn
Are you getting any check engine lights? This happened to me before, but I got about 20 different codes that couldn't have all happened at once. It ended up being a bad ECU and it had to be replaced.
Search on this forum and others, there are different diagnostic modes the Throttle Position Sensor goes into if there is an issue between the pedal potentiometer and the TPS.
2000 Boxster S, Arctic Silver, Natural Grey Leather
Factory: Aerokit I, 18" Sport Classics, Xenons, Heated Seats, Premium Sound, and more..
Upgrades: Bumper Plugs, Door Plug, Clear Sides, Clear Tails, Clear Bulbs, Painted Bumperettes, 997 Shifter, EVO Intake
dmenn is offline   Reply With Quote
Old 04-05-2009, 06:59 PM   #7
Porsche "Purist"
Paul's Avatar
Try the eGas reset procedure:
With nothing touching the gas pedal, turn the ignition on (do not crank)
Wait 90 seconds without touching the gas pedal, you will hear the throttle motor run.
Turn the ignition off for at least 15 seconds.
Start the car and see if it's fixed.
1987 924S. 2002 996TT. PST-2
