06-11-2010, 08:36 AM
#1
PSM failure message on '07 boxster
Is this reason for concern?...I am still under warranty under Nov. '10. Thanks for any input.
Boxsternut
'07 Boxster
Guards Red
06-11-2010, 09:04 AM
#2
of course it is of concern... but under warranty you should be fine. I cant imagine it being an immediate issue but you will have no PSM till its fixed.
06-13-2010, 05:37 AM
#3
Any idea what causes this error or what has to be done to fix it?
Boxsternut
'07 Boxster
Guards Red
06-13-2010, 08:00 AM
#4
no clue to be honest. I personally dont have PSM so I wouldnt even be able to help trouble shoot on my car
06-14-2010, 04:47 PM
#5
Thanks Lobo...anyone else with this experience?
Boxsternut
'07 Boxster
Guards Red
06-15-2010, 06:43 PM
#6
Since your Box is still under warranty, why are you so opposed to having the dealer fix it?
1989 928 S4 5 spd - black
06-21-2010, 03:44 PM
#7
I'm not...just haven't had time to get there yet and always like to be informed before I step into the 'shady zone' of the dealer.
Boxsternut
'07 Boxster
Guards Red
06-21-2010, 04:06 PM
#8
PSM is your stability management system, so a failure would have to be the failure of one of the wheel speed sensors, which would also affect your ABS brake system, or something in the computer that is monitoring wheel speeds.
Because of everything this system can do, like apply braking to one or more wheel/s, independent of the brake pedal, I would say it is more serious than something you can "get to" when you have the time.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
06-21-2010, 04:23 PM
#9
Did you recently have the battery disconnected? This will give you a PSM error message for the first couple minutes of driving.
06-22-2010, 04:19 AM
#10
Haven't disconnected battery at all, I use a maintainer over the winter. I did remove the wheels to clean rims and reinstalled, but that was in April. Thanks for the additional info on the PSM Quickurt. After my vacation, I plan on getting it into the dealer!
Boxsternut
'07 Boxster
Guards Red
06-22-2010, 05:21 AM
#11
When did the fault show up, right after cleaning the wheels?
06-22-2010, 06:01 AM
#12
The PSM failure light came on two months after having the wheels off, so it doesn't seem related. It only comes on at low speed, usually while turning the wheels sharply, forward or in reverse.
Boxsternut
'07 Boxster
Guards Red
09-12-2010, 01:00 PM
#13
See "psm light coming on " . Mine was the brakelight switch. Cheers
ENGLAND BOXSTER"S"UK
