Old 03-04-2009, 10:39 PM   #1
Cruise Control does not work
Ok.. the cruise control does not work in my car.. my question is that lights up on my cluster when it's engaged but nothing happens other then that. Where do i begin to figure out the problem
clb0099 is offline   Reply With Quote
Old 03-05-2009, 03:59 AM   #2
Jaxonalden's Avatar
Have you used it before? If not, the use of the controls can be a little confusing.
Old 03-05-2009, 04:31 AM   #3
The system has a pedal switch sensor. I think the one for the cruise is on the clutch. It has an adjustable plunger, if it's shot it's a cheap part to replace and an easy home fix..
Old 03-05-2009, 08:30 AM   #4
Does any one have a DIY for this clutch switch?.. it worked once before then went to ****************..
Old 03-05-2009, 11:19 AM   #5
It's worth the investment to buy a service manual, the Bentley book is a good one and should pay for itself if you plan on being involved with your own repairs. Having said that, the switch is quite easy to see on your back with your head under the pedals. As I said before, the plunger has what appears to be a ratcheting adjustment to fine tune actuation, if you're truly mechanical you might be able to restore operation of the current switch. If not, you can order one from a variety of sources, study the new part and glean what you can about how it's mounted and replaced, then carefully swap the two pieces, it should be fairly simple, good luck..
Old 03-05-2009, 11:45 AM   #6
So if i am understanding this it the Brake light switch we are talking about or is another switch?
