Old 02-04-2009, 05:58 AM   #1
cracked exhaust boxster manifold
Anyone had this problem. I have a 2002 Boxster S with 75k with cracks around the welds of the ports to the flange..2 on one side and one on the other.
Bruce007 is offline   Reply With Quote
Old 02-04-2009, 11:32 AM   #2
Can't say that I've had that problem, but if you are interested in a set to replace them, I've got a set available... PM me if you would like any more info...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 02-05-2009, 08:35 AM   #3
Ironic that you posted this yesterday. I've been working with my shop to figure out what is causing a CEL on my car. I blew the AOS a few months ago and I'm getting a Bank 1 adaptation code. My car is an 01 S with ~62K miles, daily driven.
They had the car yesterday doing some MAF logging and threw the car on the rack to check out the underside.
Basically they told me the same thing. I have cracks at the port welds on the front cylinder on each side. Evidently bank 1 is worse.
We cleared the code and I am driving it again. But I also found out I have two drips on the bellhousing... RMS starting to leak. So I was instructed to burn out the clutch, and come see them again At that point I'll probably deal with the whole sordid mess.
life is participation in evolution
87 944 PRO44 racer. 01 986S (race build in progress), 93 968
schwank is offline   Reply With Quote
Old 02-08-2009, 05:42 PM   #4
Porsche "Purist"
Paul's Avatar
Sounds like a 5 minute welding session would fix that......
1987 924S. 2002 996TT. PST-2
Old 02-08-2009, 06:38 PM   #5
Jaxonalden's Avatar
Sounds like a reason to buy a set of headers to me.
