Old 12-16-2008, 08:49 AM   #1
Bought new engine!! How much HP does it have?
I know I sound like a complete rookie but I bought an engine from a 2004 911 Carrara C4S and when i searched it and it says they come with 3.6L 315 HP which is a nice bump from what i had. Then i get the reciept in the mail and it says 04 911 (3.6L), 345 HP (x51 opt). My question is did come of those cars come with 345 HP with the x51 bump or is it a misprint? I attached a picture of the car, the exhuast does look different than other 04 C4S's. Thanks for the help!
Oh and heres the Vin # incase anyone has a carfax and can see what type of model it is: WP0CA299X4S653145
BoxsterLewis is offline   Reply With Quote
Old 12-16-2008, 09:05 AM   #2
That's going to be sweet!
http://www.renntech.org/forums/index.php?s=&showtopic=7942&view=findpost&p=39077
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 12-16-2008, 09:31 AM   #3
Porscheectomy
I believe the base was 320bhp with the base engine and 345bhp with the X51.
You "accidently" got an X51? What luck!
Old 12-16-2008, 09:55 AM   #4
haha! I must have, thats awesome! Now heres another question, the shop putting it in says they will have to use a lot of top end parts to make it fit and where the X51 makes its extra power is in the top parts..? Now i dont know how much they can use since i blew my motor with the IMS failure and i'm sure most of the top end parts like valves and cams cant be used right?
Old 12-16-2008, 10:49 AM   #5
Porscheectomy
Technically, on a horizontally opposed engine, the heads aren't on the top. You definitely don't want to use the Boxster heads anyway.
I imagine what they're talking about is the extended intake plenum from the 911 engine. It is noticeably taller than the Boxster's intake. I believe the intake piping is also larger on the 911, at least I know that the MAF section is. Using the 911 intake can be done, but the engine needs to be lowered and the cover over the engine might still need to be modified. Check with Tholyoak over on Renntech, he's done a tutorial on how to do the 3.4 conversion and I believe has since gone to an x51.
http://www.renntech.org/forums/index.php?showtopic=13527&hl=conversion+diy
http://www.renntech.org/forums/index.php?showtopic=11411&hl=x51
The ECU needs to know which intake is on the car. If you end up with the Boxster intake but the ECU think's it's the 911 intake, the readings from the MAF will be off and you'll never get the car to run right.
Old 12-16-2008, 11:41 AM   #6
This is what my mechanic doing the instal said:
Lewis,
I’m sure the engine is NOT an X51. The X51 engines have an aluminum intake and this engine does not. The other issue with the intake is the overall height.
Do all X51 engines have a aluminum intake? I know they bumped up the HP on newer 2005 engines so maybe only those have it?
Thanks for the info Blue2000s!
Old 12-16-2008, 01:52 PM   #7
edevlin's Avatar
Don't the 4S models use 3.8L engines, or was that not the case in 2004? I would love to slip a 3.6L into my Boxster, then see if it would be possible for me to keep out of trouble.....
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 12-16-2008, 04:05 PM   #8
Ed
The 996 S models like this one still had the 3.6L, but the newer 997 S models had the 3.8L.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
