Old 10-16-2008, 03:11 PM   #1
Question 99 boxster ? about replacing a bulb or alight housing
i have a 99 boxster and i believe that i just blew the bulb on the front right headlight. i have had my boxster for 2 years and she has been a dream so i dont know if i have to replace a lgiht assembly( no damage) or i can just do the bulb. may be dumb ?? but dont want to spend excess moneys.
thanks colbys986
colby986 is offline   Reply With Quote
Old 10-16-2008, 03:34 PM   #2
Lil bastard's Avatar
You can change the bulb, it's an H7. To do this, you must remove the headlight. First, pull back the lining in the trunk on the side of the affected lamp. Then, you'll see a rubber 'stopper' in the side of the trunk under the lining. Pull this 'stopper' to recveal a hole where you insert the tool from the toolkit (5mm hex on a 't' handle). Once inserted on the nut, turn anti-clockwise until you hear a loud (heart-stopping) 'pop', this has just released the headlight which will now slide forward out of the fender.
Then locate the bad bulb socket and open it by twisting, swap the bulb and slide the headlight back into the fender with some authority as you'll need to get it into the electrical connector in the fender. Then, using the same tool as before, turn it clockwise until another heart-stopping 'pop' - now the headlight is 'locked' back in place. Replace rubber 'stopper' and trunk lining and you're done.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 10-16-2008, 04:04 PM   #3
Couple of things to keep in mind:
1. when releasing the headlight using the tool from the kit, always move it towards the seating area of the car (helps avoid confusion about clockwise/anti-cw when doing it on the passenger's side headlight or the driver's side).
2. The low-beam bulb is the one higher in the headlight housing, and the high-beam bulb is the lower one.
3. Both the bulbs are the same type (H7) for halogens. So, in a pinch, you can just take the high-beam bulb and put it in the low-beam slot. You will not have high-beam on that side until you get a replacement bulb, of course.
4. Do not touch the bulb with your fingers - apparently the oil etc. present in our fingers creates hot-spots on bulbs, causing them to go out.
5. When taking the headlight out, if it doesn't seem to want to come out after the loud pop, try moving the tool just a little bit towards the front of the car (opposite of what you did to release the headlight).
It is pretty easy, and the H7 bulb is not too expensive (should be less than $20 at the dealer). Do keep in mind that you get the correct wattage - a high watt bulb will most definitely cause yellowing/melting on the inside of the headlamp.
Good luck.
bigb is offline   Reply With Quote
Old 10-16-2008, 04:06 PM   #4
In a pinch, you can swap a bulbs from either the fog, high, or low beams as all 3 (in halogen set-ups like yours) use the H7 55W bulb.
Additionally, I usually just go ahead and replace the same bulb on the other side. In most circumstances they were put in new at the same time and usually tend to go around the same time (w/in a week or 2). Of course, if you know a specific reason why, other than end of useful life, it failed you can just replace the one.
Old 04-19-2009, 07:50 AM   #5
I joined this forum for this specific problem....no low beams. You guys are very helpful!
I pulled one low beam bulb, checked it with an ohm-meter, it was open (so it was bad). I went to AutoZone, got 2 H7 bulbs, replaced them, and all is good. Took about 25 minutes.
I would always check the bulbs first (with an ohm-meter)....saves time and money.
Thanks to all of you!!
ronev
1999 Boxster, Zenith Blue, Factory Aero Kit.
ronev is offline   Reply With Quote
Old 06-09-2009, 06:49 PM   #6
Does anyone know what to do if the round clear lens (closest to bulb) gets yellow spot and cracks? What is correct wattage for bulbs? Do I have to get whole new headlamp assemblys? Thanks for any help!
Richard Griffin
Atlanta GA
2001 blk/tan Boxster 18" turbo twist wheels
2003 gray/tan Navigator
rgriffin is offline   Reply With Quote
Old 08-02-2010, 09:47 AM   #7
Angry Headlight removal tool
Please see my post regarding "bulb replacement".....has anyone else had the hex socket tool explode in their hands, almost slashing their wrists... ...and if so, what did you replace it with? Appreciate some help Guys??
BoxsterDuke is offline   Reply With Quote
