Old 09-11-2008, 04:39 PM   #1
Tire is low .. where to fill in sj ?
Does any Bay Area (CA) member know where I can go to get my tire refilled with nitrogen besides the dealership ?
I think right now its nitrogen filled directly from the dealership, but the tire is 1/2 flat.
Is it ok to mix Nitrogen and O2 and just refill (temporarily) at a gas station pump ?
nefarious986 is offline   Reply With Quote
Old 09-11-2008, 04:59 PM   #2
Track rat
Topless's Avatar
Maybe stop by your local tire shop and check for a nail in the tire. It got low for a reason. Many tire shops will refill with nitrogen on request but any old compressor will give you a nice clean 80% nitrogen blend.
Old 09-11-2008, 06:57 PM   #3
Jaxonalden's Avatar
Why are you worried about refilling with nitrogen? All nitrogen is is a dry non flammable gas. In aircraft applications it's recommended to fill the tires with nitrogen (as opposed to dry air) because of the extreme temperature swings the tires go through (-60 thru 150 degrees in a matter of minutes). It provides a more stable, constant pressure.
Down here on the ground, there's nothing wrong with using compressed air. Preferably air from a compressor with a dehydrator. If not, so what, tire pressure and tire condition should be checked on a regular basis.
BTW, to truly fill a tire with nitrogen you first need to purge out all the air before filling the tire. Good luck going through that process.
Paying a dealership to air up your tires? Please
Old 09-11-2008, 07:49 PM   #4
Thats exactly why I thought Porsche put Nitrogen in the cars stock ? It maintains pressure under heated use much better than regular oxygen. Less checking & maintenance plus some minor stuff with better mileage since your tires are always 'perfectly' inflated.
I could fill it with air, but considering I got this car 8 months ago (directly from Porsche, filled with Nitrogen stock I think ) and haven't need to deal with tire pressure, I would like to keep using Nitrogen.
I called a few local shops though, and they had no idea where I should go so I thought maybe a fellow P owner might know.
I think one suggestion from somewhere was Costco. Will check tomorrow. I'll let you guys know.
Old 09-12-2008, 02:36 AM   #5
gregdacat's Avatar
In the midwest we have a chain of tire stores named Tire Discounters. The one I go to tops my tires off with N2 for free. I think he sees it as an investment in getting my business when the Box needs new shoes. Don't know if you have Tire Discounters in your neck of the woods.
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
Old 09-12-2008, 03:59 AM   #6
bmussatti
Guest
Posts: n/a
Costco has nitrogen. They may help you in a bind. They only fill for current customers.
I have been using nitrogen since the car was new. Great for the 5 months of winter storage.
Old 09-12-2008, 04:39 PM   #7
As have been pointed out, "normal" air is 72% Nitrogen. Your tires are not filled with Oxygen. I HIGHLY doubt your tires came filled with Nitrogen from the factory, or dealer for that matter.
To get into the technical side of this, we use Nitrogen in aviation due to its inert nature, on the ground here, particularly in a street car, there is practically no benefit. Maybe if you can get your tires filled for free, sure- go for it. But if you're going to pay a premium, its ridiculous, and yes, it's a fantastic profit center for any tire shop.
If you wanted to have "Nitrogen filled tires," you would first have to evacuate the air using a vacuum pump, and then pressurize with Nitrogen. I am sure no tire shops are doing this. Now, for remote reservoir shocks, its a requirement- again due to Nitrogen's inert nature, so that's a different situation.
Long story short, I would not worry about. Just use air, though preferably dry air.
Patrick
Old 09-12-2008, 05:52 PM   #8
Jaxonalden's Avatar
nefarious986,
As you can see from my third post that nitrogen is not worth the time or cost for the little to no benefit you'll receive. Just use free, dry air and take the money you would have spent and buy some beer and invite us over to talk cars.
