Old 09-08-2008, 10:13 PM   #1
Steel wheel lugs?
In getting ready for my first DE event, I keep reading that I should make sure I have steel lugs rather than alloy. So do Boxsters have steel or alloy lugs? I haven't been able to find anything anywhere indicating which the Boxster has.
Mike_Yi is offline   Reply With Quote
Old 09-08-2008, 10:30 PM   #2
Track rat
Topless's Avatar
Your Boxster was ready for a DE event when she rolled off the showroom floor. Just make sure the tires and brakes are in first rate condition. If you have not changed the fluids in over a year that is good prep for reliability but not required.
Have fun and pay close attention to your instructor.
Old 09-09-2008, 06:28 AM   #3
You are most likely referring to the cars that have the alloy nuts (911, 944, etc). First, they are OK if properly torqued. If you are running a car with sticky tires, tech usually likes to see that the lug nut is properly engaged; hence, steel open end nuts. Your Boxster has bolts that were engineered to thread into the hub a certain distance. As long as they are properly torqued, you will not have a problem.
Old 09-11-2008, 09:35 AM   #4
Thanks for the info.
