Old 08-21-2008, 11:41 AM   #1
Loose door sill
I have found that the metal door sill on the drivers side has come loose, almost to the point where they will come off completely. Should I just use krazy glue to put it back in place? Or is there a different approach to this?
Lordblood is offline   Reply With Quote
Old 08-21-2008, 12:12 PM   #2
use 3M trim adhesive - either the goop kind of the double-sided foam tape (easier to work with). Can be found at most auto supply stores.
Old 08-21-2008, 05:00 PM   #3
Alright thanks .
Old 08-22-2008, 10:35 AM   #4
I've got the same problem. Thanks for asking. Now I don't have to.
Mike_Yi is offline   Reply With Quote
