Old 08-15-2008, 12:24 AM   #1
Send a message via AIM to blinkwatt
986 Headlight Trim
Is there a part no. for the rubber headlights trim that is between the fender and headlight itself?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 09-11-2008, 02:52 AM   #2
kt1
Good question because mine is a bit banged up from my detailing with the Porter Cable. Thinking of calling the dealer tomorrow and bugging the parts dept with finding it.
kt1 is offline   Reply With Quote
Old 09-11-2008, 10:16 AM   #3
Hmm, from looking at an exploded parts diagram I don't see an actual gasket. It might be part of the following brackets:
99650553900 left side
99650554000 right side
only $15 bucks/side from Pelican Parts
shaman1204 is offline   Reply With Quote
Old 09-11-2008, 10:51 AM   #4
Originally Posted by kt1
...mine is a bit banged up from my detailing with the Porter Cable....
Sorry I do not have a part # and this doesn't help the one(s) you already have damaged but.....
When detailing, especially when using the PC or my rotary, I always just pop out the headlight pods and store them in the front trunk. This keeps wax/polish residue off the trim and makes it a snap to spritz them up w/ a little Mothers Back to Black before reinstalling. On the 9x6s they're easy enough to pull out w/ a 5mm nutdriver or the tool in the tool kit. I also usually remove the hood crest (w/ an 8mm nut driver as sockets tend to be a little to fat to get into the recessed holes).
Good luck
Old 09-11-2008, 11:10 AM   #5
F.Y.I. there is a part no. if you remove the screws holding the gasket on the headlights..........it can't be ordered seperate from the headlight.
I needed to order some because the headlights gasket were fitted to the past car's fender they were on, leaving me with a small gap on mine. I fixed this by removing the gasket,getting a very very thin cloth towel,cutting it to fit between the headlight and the gasket and now they sealed everything up. The towel pushed out the gasket enough to close the gap between the headlight gasket and the fender. It may sound confusing but you will see what I'm talking about after you remove the gasket.
Old 09-11-2008, 04:22 PM   #6
I've got mine from my old litronics? $20 + shipping?
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
