Old 07-26-2008, 03:47 PM   #1
Quickurt's Avatar
987 forward mud-flap replacement?
The official part designation is cover,lateral. It is the mud-flap looking thingy that is in front of the rear wheel, at the end of the rocker panel. It looks like it goes under both the rocker trim panel and the inner fender panel......
Has anyone replaced one?
A little guidance would be nice.......
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
Old 07-26-2008, 04:13 PM   #2
Lil bastard's Avatar
I've done it on a 986, but not a 987. Hard to describe, but you do have to work it through some unexpected way.
Best suggestion is to remove the old one and simply reverse the procedure.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 07-26-2008, 05:15 PM   #3
Quickurt's Avatar
Is that like learn to pull the engine by putting one in and reversing the procedure??
Old 07-26-2008, 09:09 PM   #4
Almost
1976 BMW 2002
1990 BMW 325is
Old 07-27-2008, 07:11 AM   #5
Quickurt's Avatar
Almost
Too funny, LB!
I guess I 'll start today by doing a search on removing trim rivets.
Old 07-27-2008, 07:56 AM   #6
EE3racing
Guest
Posts: n/a
Originally Posted by Quickurt
Too funny, LB!
QK,
If you are talking about the lower front flap, which I think is a wind divertor for brake cooling. It's attached integrated with the bumpercover hardware, it's only held by three fasteners.
Old 07-27-2008, 08:29 AM   #7
Quickurt's Avatar
Originally Posted by EE3racing
QK,
It is the wind diverter in front of the right rear wheel. It was attached with 5 star drive screws and came right off, new one went right on. Piece of cake!
I took a nice trip on July 4th. Took all farm roads up across rural Georgia to my buds house west of Macon. Moved over to miss a tree branch in the road and then had to nick the branch to miss the farmers Bulldog running out to "get me."
The branch punched a hole in the hollow plastic trim part. The alternative would have been far worse for all parties involved......
Old 07-27-2008, 05:31 PM   #8
here's a picture of the part from suncoasts website ~ $24 each
Link to Part on Suncoasts Site
on the 986 it's extremely easy to replace......
- remove the two 10mm nuts holding the forward piece of the rear wheel well liner
- remove the three philips head screws on the bottom of the flap (2 will be in the rocker panel area - one interconnects w/ the under body panel)
- remove the one philips head screw from inside the wheel well (hidden by the previously removed wheel well liner)
I would assume the procedure on the 987 is very similar. Hope this helps
