Old 03-10-2007, 09:20 AM   #1
Notes for Titronic S Owners...
Hi,
Last year when prepping my car for storage, I discovered that the Gasket around the ATF Pan on my Tiptronic was leaking. The issues here are two-fold; first, you have smelly fluid dirtying up the underside of the car, but more importantly, as the 5HP-19 lacks a diptick, there is no easy way to determine whether your fluid level is dangerously low. Late last year, especially on hot days, I did notice a slight degradation of the Tranny's shifting - a possible indicator of low fluid.
So, I bought the Gasket and Filter in preparation of repairing it this Spring. What I didn't do was buy the ATF Fluid to replace that which I'll drain off when removing the Pan. This is because the Fluid - ESSO LT 71141 is extremely expensive (as much as $55/Litre) and only available in 20L containers - $1,100! I decided not to shelve that much cash for the Winter.
In the interim, I have been doing much research into this Tranny and the unique fluid it employs. It turns out that this transmission - a ZF Getriebe 5HP-19 A 86.00 (A 86.05 for 2.7L and A 86.20 for 3.2L 'S'), or some very close variants, are also used by Audi, BMW and Jaguar. All these manufacturers, like Porsche, claimed that the Fluid was 'Lifetime' (the LT in ESSO LT 71141 stands for Lifetime). And that a Fluid and Filter change was not due before 90k mi. But, recently, both BMW and Jaguar have revised their Service Interval and lowered it to 40k mi., whether Porsche will follow suit remains to be seen, but I plan on adopting the revised Service Interval, because in my experience, ATF usually had a change interval of 15k mi.
The key here isn't so much a breakdown of the ATF as much as it is removing the sludge, metal shavings and clutch material (the 5HP-19 A 86.00 employs 5 internal clutches - one for each gear with 5th and Reverse sharing one as they reside on the same shaft) from the fluid supply.
Several people looked for, or were touting cheaper, more readily available, ATF alternatives to the ESSO LT 71141. Also, since the Filter/Fluid change only resulted in the loss of 7L of fluid at most, many were averse to having to buy it in 20L packaging (espec. @ $55/L). The most common alternative fluids were Pentosin ATF1 and Audi's own ATF (which is just repackaged Pentosin). This fluid could be had for around $25/L. Another alternative was Redline D4 ATF, Synthetic and about $11/L. Each of these showed it was compatible with ESSO LT 71141.
But, from the ZF Getriebe site directly, there are no approved alternatives to ESSO LT 71141. In the dizzying world of Hydraulic Actuators, Electro-Hydraulic Clutches, etc. that make up today's modern Automatic Transmissions, often a specific fluid is approved for use and using any other can cause accelerated wear, poor shifts, higher operating temps, etc.
Since I would not be draining all 15+L of fluid from the tranny (incl. the Torque Convertor), any alternative fluid would give me a mix of about 50/50 ESSO LT and something else. I did not find this alternative too attractive. I was still averse to buying 20L of the stuff for a 7L job, so I continued to research sources of supply for the ESSO LT.
It is commonly available in Canada in 1 L bottles and at significantly lower prices, but Trade Barriers prevent it's importation. Exxon-Mobil is the Parent of ESSO, so I called the local Exxon-Mobile distributor and was again told it is available only in 20L containers, but at a Will Call price of $25/L, better, but still waay too high for what amounts to only ATF - not some Magic Youth Elixer.
I started researching BMW, Audi and Jaguar aftermarket parts suppliers and found two which sell it in 1 L bottles - 1 for $18/L and another for $13/L. So, I ordered up 7L of the stuff, along with 2L of ATE Super Blue Brake Fluid. I bought the $18/L stuff because this Co. offered Free Shipping on Orders exceeding $150 (which is why I threw in the ATE - 26lbs. total shipping weight) and resulted in a lower NET purchase than the $13 stuff w/ S&H.
Anyone wanting this info., just PM me and I'll supply it. In sum, I think it's better to do the Filter Swap and Fill at 40k mi. rather than the Porsche recommended 90k mi. for increased Tiptronic health and expanded lifespan. The procedure is relatively simple and I plan to photo-document it and post it in the DIY section in the coming weeks. Hope this helps...
Happy Motoring!... Jim'99
Old 03-10-2007, 10:14 AM   #2
Allen K. Littlefield's Avatar
Thank you
Good info. as my '02 Tip is just over 35k. I will save your photo documentation when you release it.
986geezer
Old 03-10-2007, 01:36 PM   #3
07 Carrera S Cab
Boxtaboy's Avatar
Titronic? Must be an exciting new feature!
Old 03-10-2007, 03:37 PM   #4
Jim,
Thanks for the info! I'll be looking forward to the instructions for changing the Tip fluid. I'll probably change mine soon to get rid of the metal shavings and gunk that may be in there.
Georg
2003 Boxster Seal Gray/Gray
TIP
5000 miles (for some reason I'm proud of this)
porschegeorg is offline   Reply With Quote
Old 03-11-2007, 04:35 AM   #5
bmussatti
Guest
Posts: n/a
Great write-up, Jim! Very resourcefull.
Old 03-11-2007, 07:40 AM   #6
Thanks for the info Jim! Looking forward to the write-up!
dcporsche99 is offline   Reply With Quote
Old 03-11-2007, 04:36 PM   #7
JAG
I just bought a 2001 Boxster S with a Tiptronic and looking through the owners manuals, it just states ATF for the trans fluid... I'll have to re-read them and see if I'm just not remembering corectly....
...Joe
2001 Boxtster S - Triple Black
JAG is offline   Reply With Quote
Old 03-11-2007, 04:42 PM   #8
fab
fab's Avatar
Tip owner as well with 35K. Jim, looking forward to the write up.
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 07-20-2008, 07:29 PM   #9
hi
i am a new boxster owner. just bought mind last fall, live in invergrove mn.my car is a 1997 with 26000 miles in it, just happy to see someone from thesame state in the 986, you seem very knowlegeable about the boxsters, i have a thermostat problem, so i think. my gauge stays at 100 for a good 10 to 15mins of hard free way driving, then sometimes during thesame kind of driving it might shoot up to 180, but never above that.Is it normal for the gauge to stay at a 100 for that long ? thanks plenty hope you have a good day
bonvita1973 is offline   Reply With Quote
Old 07-21-2008, 09:37 AM   #10
I'm thinking this is probably a good thing to do.
My 2000 S tip now has 62000km. on it.
Does anyone know what the dealership or an indy will charge for this service?
Cheers
Mike
MikeM is offline   Reply With Quote
Old 07-22-2008, 01:19 PM   #11
MNBoxster...
Jim..I tried to PM you but was not allowed for some reason.
I'd really like some more info about this ATF fluid. I'm in Canada and have some interesting info for you. Could you supply me with a phone number or email address where I could reach you?
Cheers
Mike
