Old 06-30-2008, 06:21 AM   #1
Stainless Door sill
Does anyone have one extra STAINLESS STEEL door sill maybe from a scraped boxster or under a bench somewhere. I only need one don't ask what happened to mine lets just say after you stick it on it don't come off very easy!!!
Also I'm looking for the black grill from the air intake port on the drivers side of the car. It looks like my 02 was desnorkled by a previous owner and one of the tabs on the grill is broken.
Also I need the screw and plastic body nut that holds the body trim ring and that grill in the intake, the screw and nut is missing.
It's the screw at the 12:00 clock position and it screws up through the intake body trim and into a plastic nut on the body inside the rear fender.
brian2034 is offline   Reply With Quote
Old 06-30-2008, 06:39 AM   #2
There Is No Substitute.
rick3000's Avatar
You should post this as 'Wanted' in the classified section.
