Old 05-21-2008, 06:19 AM   #1
What temp for Low Speed on Fans?
Hi all,
I am trying to see if I am missing my low speed on both sides. From what I remember the other day, as my temp gauge hit the 0 on the 180 the fans kicked in.
The sound seemed to be the same as when the AC is on so I am guessing I have two blown resistors (two dead relays seems unlikely).
At what point should I have been hearing the low speed engage?
Thanks!
Chris
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 05-21-2008, 06:45 AM   #2
I dno't have the answer for your question, but a little bit of hijacking here....seems to me to be a good hack and easy to do. Mount some LEDs on the panel to let you know when your fans are running, and on low or high speeds. Doesn't cost but a few dollars, no big deal to install, won't take much room on the panel, and gives you some good info.
Kevfra is offline   Reply With Quote
