Old 05-11-2008, 01:53 PM   #1
2002 Boxster obc hack
Can someone confirm the correct pinout numbers for the wiring on a 2002 when doing a complete 4 stalk hack.
TOOLPANTS???
There's a couple of different threads I came across and some don't mention the year car there doing the hack on. I just want to verify the numbers for the wiring from the obc stalk to the grey connector on the cluster for a 2002.
Hate to have to pull it apart againnnnnn for a misplaced wire!!
Toolpants send me a email with your address and I will send you a cluster reset shaft for your new TOOTHPICK
Thanks Brian
brian2034 is offline   Reply With Quote
Old 05-11-2008, 02:08 PM   #2
There Is No Substitute.
rick3000's Avatar
Have you looked here:
http://www.whiteson.org/boxster/mods/obc/
There are also so links to other sites with more information at the bottom of the page.
Old 05-11-2008, 02:58 PM   #3
Yes I checked that web page and the links on the bottom of the page. The page is for a switch hack not a 4th stalk hack and the links are for early year Boxster
Old 05-11-2008, 03:59 PM   #4
Pin on stalk, Cluster pin (Grey), Wire colour
1 , na , bn/bu, this goes to ground
2 , 23 , wh/bn
3 , 22 , ye/bn
4 , 21 , gy/bn
5 , 24 , bu/bn
-Todd
Current Cars:
1989 911 Targa
1984 944 Original Owner
1971 911T
tholyoak is offline   Reply With Quote
Old 05-11-2008, 05:19 PM   #5
Thanks Todd
That's what I had but just wanted to be sure, I don't like doing things twice
Brian
Old 05-11-2008, 09:28 PM   #6
For 2001-2004.
The female connector to the stalk has 6 slots for 6 pins but only 5 are used. The mating male connector you need to buy also has 6 slots but only 5 are used. On both connectors the slots are numbered 1-6. Slot 6 is not used.
As Todd said. The wire from slot 1 on the male connector goes to ground. The wires from slots 2-5 of the male connector go to the 32 slotted grey instrument cluster connector.
The info on that site is wrong. The VW wires you need for a 2001-2004 is 000 979 009. You need, of course, 5 of them.
VW has jacked up the price so shop around for the wires.
Tool Pants is offline   Reply With Quote
