Old 05-08-2008, 05:26 AM   #1
Boxster jack points
Hello, hoping someone can confirm the proper jack points under the boxster to hold jack stands without damaging the underside. I'm hoping to do some cleaning in the engine area. I recently had the RMS seal replaced and want to clean up any residual oil so I can tell if its leaking again or not.
Thanks,
Rosso
rosso is offline   Reply With Quote
Old 05-08-2008, 06:26 AM   #2
If you just want to be able to get under the engine and clean, get some ramps and back it up onto them. Cheap, easy, and safe.
If you really want to go the jack and jack stands approach, it's been talked to death here on the forum, complete with pictures. Just use the search function.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
