Old 04-22-2008, 09:42 PM   #1
dash clock knob
where can i find a new clock knob for the dash (mine broke). please advice.
thanks
CESONI is offline   Reply With Quote
Old 04-22-2008, 09:58 PM   #2
Lil bastard's Avatar
The part is PN#996.641.911.00 or .01 (one is the clock, the other the instrument dimmer/trip odo).
A dealer will likely need to order it for you - inexpensive.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-22-2008, 10:20 PM   #3
Thank you, I ordered online for $8.95.
Old 04-22-2008, 11:02 PM   #4
On your year it is usually the plastic stem for the knob that breaks, when you hit it with something, like a cleaning cloth. The knob does not break.
Picture test.
Old 04-23-2008, 09:47 AM   #5
Picture test.
thank you, the knob is actually missing not broken. if i had to replace the plastic stem, how hard is it?
Old 04-23-2008, 11:43 AM   #6
Thumper's Avatar
Pretty easy really. Once you have the cluster out of the car, pull the clips off of each end, pop the front cover off, then take out the screws on the back of the cluster. The back will come off fairly easily (slides straight up). You will need to have the cluster face down and you need to be careful not to move the needles on the gauges. The broken pin comes out easily and the new pin goes in the same way the broken pin came out. Slide the rear cover back in place (the openings for the harness plugs can sometimes fit really snug into the openings). Once it's fully seated, put the screws back in, flip the cluster over and reinstall the front cover (just snaps into place) and reinstall the clips on the ends.
You do have to hold your tongue just right when pulling the cluster apart and putting it back together.
Thumper is offline   Reply With Quote
Old 04-23-2008, 12:14 PM   #7
Porsche does not sell replacement stems, only the knobs.
Old 04-23-2008, 12:29 PM   #8
Thumper's Avatar
I do have to admit that all of the stems I've installed came from other clusters. If your stem is broken, I'd try to find a cheap cluster on eBay that has a good stem in it. Or, you could just upgrade to the Carrera cluster.
Old 04-25-2008, 07:55 PM   #9
[QUOTE=Tool Pants]On your year it is usually the plastic stem for the knob that breaks, when you hit it with something, like a cleaning cloth. The knob does not break.
Picture test.[/Q
you were right, the plastic stem is broken. How do I replace it?
Old 04-25-2008, 08:10 PM   #10
Thumper's Avatar
See my first post for how to replace the shaft.
The knobs are super easy as they just press on.....gently.
Old 04-25-2008, 08:21 PM   #11
got it, thank you
Old 06-08-2008, 01:11 PM   #12
Picture test.[/QUO
Where can I buy those plastic stems?
thanks
Old 06-08-2008, 01:14 PM   #13
plastic stems for the dash clock
where can I buy the plastic stems?
Old 06-09-2008, 12:00 AM   #14
instrument cluster reset shaft
Old 06-10-2008, 07:19 AM   #15
Thank-you TOOLPANTS
I guess a ad on the site would help people find the cluster shafts??
I find myself just reading the latest posts in the general discussions and not using the search engine to find what i'm looking for on the site.
brian2034 is offline   Reply With Quote
