Old 04-16-2008, 03:30 PM   #1
18" to 19" wheels
SO im thinking about changing my rims from 18" x 8.5" front 18" x 10" rear to 19" x 9" front and 19" x 11" rear. Im afraid tire cost for the 19's will be too much, any idea?
Also is running stretched (look) tires bad?
Whats a Porsche?
2000 Porsche Boxster
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Custom Dual Magnaflow Exhaust
Custom Rear Diffuser
http://img255.imageshack.us/img255/6...umpic23bg5.gif
Where's my car? is offline   Reply With Quote
Old 04-16-2008, 07:09 PM   #2
I just put 19" on mine. No problems with fit, or rough handling. EBAY look up 19" rims Eurotech. black silver or chrome finish starting at $695 for four, with center caps.
1999 Boxster
Triple Black (Basalt metallic)
Silver Carbon Fiber Interior,De-Ambered,Euro LED Taillights, Eibach Pro Kit lowering springs,EuroTech 19" wheels/Kumho tires,Turbo spoiler,Clear halogens
Gemballa red face gauges ..(FOR SALE)
http://i28.tinypic.com/2zzlq29.jpg
986speedster is offline   Reply With Quote
Old 04-16-2008, 09:33 PM   #3
jonnycool's Avatar
yep me too, 19" kahn RSR split rims 8"front 9 1/2" rear i think, best move i ever made, 235/265 michelin sport 2 tyres, a little pricey when they first came out though (between $5000-$6000 with tyres), my other tyres were bridgstone S02's a great tyre but alot more road noise than the michelin.
jonnycool is offline   Reply With Quote
Old 04-16-2008, 11:53 PM   #4
do you think i need spacers for the 19 x 11 rear's??
Whats a Porsche?
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Old 04-17-2008, 02:04 AM   #5
i dont think you can even put 11's FYI... i called up a couple of the big wheels sales including that eurotech place and also went to a local shop and asked about putting 11s and they all said nope, can't do it...they all did the same thing, offered me 9.5s in the same wheel for the rear. i got a feeling to fit the 11s you would end up with a lip thats too big, like 6 inches or something, and even though the rear lip looks cool, overdoing it is a little weird not to mention i have seen 10s or 10.5 on a boxster with a nice size lip and they sort of stuck outside the fenders on the rear...it looked a little ghetto, it should be just a cm inside the wheelwell...contact ebay sellers to see what they say, im eager to know if there is an 11" width that i can roll too.
ut_cougar is offline   Reply With Quote
Old 04-17-2008, 04:55 AM   #6
Wingnut2u's Avatar
There is no way you will be able to fit an 11. The largest you will see is a 10.5 and that is with a 265 tire that will be stretched and will look a little too ricer for most, not to mention the hassle of offset and spacers.
That being said, I got a good deal on some wheels and I am currently trying to fit some 10.5 Cargraphic Racing wheels that were on a 996 on my 01 Boxster S. I took my car to Ruf and they tried but they couldn't make it work with the 285 tires that were on the wheel. We are going to try different tire size options today and see how they look and if we can fit them on the car.
If they don't fit then maybe someone on here will have an interest and want to buy them.
Getting larger wheels on a Porsche is a science. I would look for wheels in 9.5 just to take the guesswork out of it and no larger than 10 just to ensure proper fitment
Now if I could only just follow my own advice
Wingnut2u is offline   Reply With Quote
Old 04-17-2008, 05:34 AM   #7
The tire cost from 18's to 19's is not a small jump. Right now 18's are the sweetspot for wheel/tire prices, just like in prior years when 16s the were the 'affordable' setup when 17s came out and subsequently 18s when 19+ came out. Give it another year or two with wheels getting larger and even more common and 19's will probably move into the more affordable range, if $ is an object.
I have a friend who has 19's on his boxster in which I believe the rears are 19x11's, they came off a turbo. I can double check if anyone is interested. I do know he had to roll his rear fenders to get them to work though.
- ian
idheaton is offline   Reply With Quote
Old 04-17-2008, 06:56 AM   #8
I have 19 x 275 x 10.5 rims/tires and from what i know they were not stretched on....
If you decide to put a 11" width, i think all you have to do is put a bigger spacer.
my 10.5" was very close to my strut on the inside, so i had to put a 7mm spacer to clear a piece of cardboard through the gap from inside rim to strut. the car has also been lowered 1.3 inches(this makes a difference).
I DO NOT RECOMMEND a 19" tire on a 2000 boxster... It will slow the car down and the overall suspension can't handle it over time. i've been driving on 19s for over 3 years, and i can feel the wear and tear. If i could go back in time, i would of put a 18inch rim and lowered my car 2inches instead of the 1.3 inch drop. If you decide to go with a 19inch rim, try and stay within the porsche recommended! 19x 265x10......11 inch width isn't a great idea.
18 x 265 x 10 with a 2 inch or 1.3 inch drop is the right way
p.s if your just looking for crusing tires, and not in need of super expensive tires for the track....check out general exclaim tires. i drove 30k on a set and i drive rough and hard! the front tires still look brand new, after 30k of driving. the rear needed to be changed after 30k. i just changed my rear tires last week, and the grip is insane!! check the ratings on tirerack.com!
986Roadster is offline   Reply With Quote
Old 04-17-2008, 07:11 AM   #9
another issue that i have...........kind of hard to explain, but here it goes!
when i stand behind the car on an angle, looking at the back of the car, and
the rim from a distance. the rims look too big. they don't fit the car. the back bumper looks awful. the rim looks like its sticking out and has a very odd look.
i hope this helps. buttt if it helps, i didn't listen to anyone when i bought my rims. i went with the look that i wanted. one things for sure....the car looks amazing!! from the side to the front to the back of the car, it looks mean!!
Old 04-17-2008, 08:50 AM   #10
19" rims can slow you down?? care to explain more? thanks
Whats a Porsche?
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Old 04-17-2008, 09:46 AM   #11
This is funny actually.. I had 11" wheels on the car yesterday with 295 and no problem with clearance. I went back to 18"s with a 285 tire for a little while until the 19" wheel I want is available with my offset. But either my boxster is different than any other boxster out there or it works with that wheel..
cristopher
*youth is wasted on the young*
Photos of my Boxster S
Painted center console, artic silver
, De Snorkle, 18" Carrera lightweight - 285-30-18 - Fabspeed Exhaust
http://www.cristopherbenitah.com/boxster.jpg
cbenitah is offline   Reply With Quote
Old 04-17-2008, 11:54 AM   #12
I think he is right. I too share this belief. It all has to do with adding more weight to the rear hub and flywheel. The lighter the rim, the less weight put on both and you can usually feel the difference in pick-up. So unless you can find a super light-weight rim that is still 19" you will be adding more weight and stress to the rear axle. I choose the 18s with a lowered stance for better handling and looks. When I owned a Mazda RX7 and had 17" racing rims on it and then switched to 19"s just for looks, I noticed a significant loss in pick-up and torque. So ever since I bought my Boxster, I swore I would not go over 18s. Hope this helps. Cheaper on your wallet too, since we cannot rotate the tires front to back like other cars. And you will go through rear tires fast if you are a daily driver.
porsche986spyder is offline   Reply With Quote
Old 04-17-2008, 02:51 PM   #13
I have 18 X 10's on my car with an ET 47. I don't know how 11s would fit, as the tolerances are tight with the 10s. My car is also lowered quite a bit so the "rim" could not extend beyond the wheel lip and I sure wouldn't raise the car to make it fit and look like a 4 X 4. As is, I had to cable tie the parking brake cable to the lower arms so it wouldn't rub on the tire.
Old 04-23-2008, 09:37 PM   #14
I run an 18x10 ET45 and I find that to be perfect. You can run ET40 on a 10" rim but that is absolutely outer limit if you expect the tire to clear the fender. I know some guys run a 10.5, but I don't see how there is room for an 11" rim if you still want to keep fender clearance on the outside.
As to spacers, you only need spacers if there is not enough offset in the wheel. The sweet spot for a 10" rim is 45-47mm.
The 996 Turbo rears are 18x11 ET45.
Patrick
Old 05-09-2008, 10:05 PM   #15
Actually this has to do with highschool physics of "Rotational Inertia". Wikipedia this
When putting more mass outside rather than inside, it takes more time to slow it down and also to speed it up. i.e. More metal rather than rubber with 19 rather than 18s.
It's similar to an figure skater, you see how they pull their arms inwards when doing a spin? It makes them go faster.
hqduong is offline   Reply With Quote
Old 05-09-2008, 10:06 PM   #16
Also keep in mind, in reality, Rims should only be enough to accommodate the brakes. Enough to cool it down. If don't care about performance, and looks, get bigger rims. If performance is critical, then smaller size.
Old 05-11-2008, 01:02 AM   #17
The right look
I have 18 x 10 with 285 Perelli's on the back of mine and they fit perfectly just on the edge of the grear guard. My car had standar suspension & I have no issues with rubbing.
When I got the car it had 16"'s on it and I could definately tell the difference in reduced acceleration when I put on the 18"s. But it looks a hell of a lot better so I suppose it's a trade off. 285's look great from the back, gives the car that fat bum look.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
Old 05-12-2008, 11:57 AM   #18
What is the brand of your wheels and where did you buy them They look great.
BOXZING is offline   Reply With Quote
