Old 04-02-2008, 10:00 AM   #1
cruise control not working?
My cruise control was working before sometimes it would ok and then sometimes it would not ?now it does not seem to be working at all is there anything to look for a quick fix ?
rd400rz is offline   Reply With Quote
Old 04-02-2008, 10:18 AM   #2
Lil bastard's Avatar
What year? Model? TipS or Manual? all these things can make a difference
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 04-02-2008, 10:33 AM   #3
cruise not working
mine is a 1998 manual tranny thanks for any help
Old 04-02-2008, 03:39 PM   #4
The issue is most likely a bad switch, or the cruise control unit. But 1st, check Fuse #B7 to be sure.
If the fuse checks out, then you're going to need a DMM and a wiring diagram to make the necessary checks to narrow the issue down to either the switch or control module. You will also need to pull the steering wheel in order to remove the column switch and access the electrical connector.
If you're comfortable doing that kind of work and have the necessary tools, IM me and I can send you the wiring diagrams, etc.
1976 BMW 2002
1990 BMW 325is
Old 04-02-2008, 04:08 PM   #5
EE3racing
Posts: n/a
Make sure to check the switch on the clutch pedal, it has an adjustable plunger, mine went bad, easy to replace and the cruise works fine now. I'll bet you that's whats wrong, easy fix fairly cheap part...
Old 04-03-2008, 09:10 AM   #6
Excellent point! I misread and thought he had a TipS. Thanks for catching it!
Yes, the Clutch Switch is also very much on the list of possibilities.
1976 BMW 2002
1990 BMW 325is
