Old 03-27-2008, 12:49 PM   #1
Changing Brake Pads
It is getting tome for me to change the brake pads on my 2002 S.
Is this a DIY job or should this go to the dealer?
If it is a DYI - can anyone recommend the brake pads and maybe some instructions?
Thanks in advance
mikedivincent is offline   Reply With Quote
Old 03-27-2008, 12:58 PM   #2
If you have a few simple hand tools, you can do this yourself. In fact, once you learn how to do it, you will never let a dealer do it for you ever again. Pads are so easy to change its nearly a sin how much shops charge for this
If you like the performance of the original pads, get another set. For everyday use, they are hard to improve upon.
You mention its time to replace pads.. when was the last time the brake fluid was changed? If its been more than 2 years, you might want to add this to your list of things to do. Not difficult here either, especially if you buy for about $100 or less, a Motive Power Bleeder and catch cans. It becomes a one man job.
I recall porsche recommends changing Rotors too, somewhere around every 2nd brake pad change. Something else to consider. And again, not a hard thing to do either.
Or, take it to the dealer and have them do all this work for likely $2000!
Lots of folks out here will lend advice and if you are close enough, someone would likely volunteer to come over and help you out!
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 03-27-2008, 12:59 PM   #3
It's one of the easiest brake jobs there is.
Here's a link to DIY for pad change (along w/ links for rotor change and bleeding if you're so inclined)....
Can't beat DIY. Don't forget to reward yourself accordingly when finished
Trygve Brake DIY Link
Old 03-27-2008, 06:17 PM   #4
Definitely a DIY! The least expensive brake pads for street use are probably Mintex (in the red box)...w/c you can purchase on Ebay for roughly $120 for both front and rear brakes.
IMHO, I don't think you'll need to change out your rotors unless there's something wrong with them (re: warped), you have close to 100K, and/or you track your car often.
As for the brake fluid, as racer_d mentioned, you can purchase a Motive Bleeder (<$70 from Performance Products or elsewhere---do a quick search on the forum) that will allow you to bleed the brakes yourself.
Good luck and enjoy learning about your car!!
Keep us posted
dcporsche99 is offline   Reply With Quote
Old 03-27-2008, 07:01 PM   #5
Lil bastard's Avatar
You should definitely check the rotors. Rule of thumb is every other pad change. Pads go 35k mi. maybe, so at 70k mi. you're definitely due.
Or you can be precise and check them with a micrometer or a vernier caliper. For Boxster S, you have a minimum thickness of 22.6mm (0.89") Fr and 18.6mm (0.73") Rr.
Wearing the rotors below this minimum thickness will drastically reduce your braking efficiency and can cause a premature rebuild or replacement of the calipers.
Also, if sticking with the existing rotors, be sure to at least sand them down with #40 paper and a block. This will remove the previous pad material and allow a layer of fresh pad material to build-up on the rotor face - a necessity for reaching max braking efficiency.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 03-27-2008, 07:08 PM   #6
Is that 40grit? Or do you mean 400grit?
Rareair is offline   Reply With Quote
Old 03-27-2008, 07:22 PM   #7
Yep 40 Grit. Just a light twice around with the paper on a block will do it. This will also create enough roughness for the new pads to wear-in properly. May seem agressive, but it's not.
If you used 400 Grit, you'd likely cause the rotor/pad to glaze
1976 BMW 2002
1990 BMW 325is
Old 03-28-2008, 08:17 AM   #8
If youre short on time, has anyone taking it to a regular brake shop like midas or something, or is that bad?
BoxsterLewis is offline   Reply With Quote
Old 03-30-2008, 10:52 AM   #9
Just me, perhaps, but I wouldn't let the local Midas change brake pads on a tricycle!
"The car you've dreamed of owning is the same one our designers and engineers dreamed of building."
Peter Schwarzenbauer
My car @ Car Domain
http://img.photobucket.com/albums/v2...nstalled01.jpghttp://img.photobucket.com/albums/v2...nstalled02.jpg
Arctic Silver '05 Silver Boxster
Uncle Bob is offline   Reply With Quote
Old 09-06-2008, 11:16 AM   #10
Brake Wear Sensor
Has anyone bypassed the brake wear sensors?
I just put on new pads, but did not buy new sensors.
Some are worn down, and the break wear light is still on in the dash.
Can you twist the 2 wires together to bypass the sensor?
mdivincent is offline   Reply With Quote
Old 09-06-2008, 11:36 AM   #11
The wire is the sensor. Once worn through, it completes the circuit for the warning light. You should be able to strip the ends and twist them together. Then just hang or wire tie the wire out of the way, but still plugged into the conector.
It's fairly common for people to do this and not bother putting the wear sensors back on the new pads.
Many owners are so tuned into their car's maintenance, that they don't need a reminder to let them know the pads need changing anyway.
1976 BMW 2002
1990 BMW 325is
