Old 03-21-2008, 03:26 PM   #1
No fluid coming out of nozzles?
I had the windshield fluid light on and filled her up and when i push the handle for fluid to come out it makes a sound and nothing comes out and when i got out of the car it was all over the ground??
BoxsterLewis is offline   Reply With Quote
Old 03-21-2008, 03:44 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Simple fix. Happened to my car too. Turn the steering wheel all the way to the left, and then get out of the car. Go to your driver's side front wheel area and remove the 2 plastic nuts and one plastic rivet in order to pull back the rear section of the wheel liner a bit. Once you pull back the wheel liner, you will see up there that there's a hose that connects to the nipple of the washer fluid tank. The hose most likely just came off the nipple, which allows all the washer fluid to just drain to the floor.
Reattach the hose to the nipple of the tank and then secure it with a small hose clamp. That will fix it for good. Then just reattach the wheel liner, and you're done.
Old 03-21-2008, 04:13 PM   #3
Thanks boxsterboy, i will def try that!!
