Old 03-21-2008, 03:44 PM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Simple fix. Happened to my car too. Turn the steering wheel all the way to the left, and then get out of the car. Go to your driver's side front wheel area and remove the 2 plastic nuts and one plastic rivet in order to pull back the rear section of the wheel liner a bit. Once you pull back the wheel liner, you will see up there that there's a hose that connects to the nipple of the washer fluid tank. The hose most likely just came off the nipple, which allows all the washer fluid to just drain to the floor.
Reattach the hose to the nipple of the tank and then secure it with a small hose clamp. That will fix it for good. Then just reattach the wheel liner, and you're done.
