Old 03-08-2008, 07:54 AM   #1
Question 17" Rim suggestions PLEASE~!
Im looking to get a 17" rim for my 986 (7/8.5J) - same size as stock 17" just because that is the only size that would fit in my TINY car garage in Tokyo. Since the rim spec needs to be 5H-130 to fit, would anyone know what aftermarket 17" are out there for our boxster??? I've so far only managed to find one 17" with 5H-130 and that is the WORK BROMBACHER rim... and nothing else
http://www.vividracing.com/catalog/work-brombacher-step-lip-wheel-17x70-5x130-p-35438.html
Thanks so much!
falcon123 is offline   Reply With Quote
Old 03-08-2008, 09:10 AM   #2
Check out tirerack.com... if they ship to Japan, they can display a bunch of rims that could work. You can even view how they would look on your car.
Wait, how would rims with a larger diameter make the car not fit in your garage?
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 03-08-2008, 10:09 AM   #3
friggin jpop carparks
"Wait, how would rims with a larger diameter make the car not fit in your garage?"
--> Its one of those mechanical carpark where the wheels go on metal tracks and hauled upwards... Hence current clearance on each rim is only 3cm from the outer tip.. I doubt there are any 7J/8.5J 18" rims out there.. thanks for the input tho ill check that site up now.
Old 03-09-2008, 11:44 AM   #4
In Japan, many car park structures use a carosel/ferris wheel type system to save on space. Looks really cool when in motion.
Rareair is offline   Reply With Quote
Old 03-12-2008, 06:47 AM   #5
Cool SSR Professor MR1 FITS?????
Will SSR Professor MS1 18/19" (7J/8.5J) fit our 986? The bolt pattern for this rim says 4/5H 98-114.3/98-130 and Im not quite sure how to interpolate that..
Does it mean it comes in 5H-130??? If so, that'll be sweet..
SSR Professor MS1
Thanks for all the inputs!
Old 03-12-2008, 03:50 PM   #6
No the bolt pattern diameter is wrong. You need 130mm not 114.3. In general SSRs work best on Japanese cars. Lots of Japanese cars use 5x114.3.
Ooops. I went to the site and it looks like they do have 5x130. But to be hones I don't know if the center bore and offsets work for the Boxster. In my 17" size they would be about 1/4" too far in.
renzop is offline   Reply With Quote
