Old 03-06-2008, 10:15 PM   #1
If you're trying to restore the colored crest caps, here's a simple suggestion. Take some 1200-1500 grit wet/dry sandpaper and rub the top layer of the crest. Afterwards, apply some Meguirs/Mothers polish or hand glaze.
Or you can simply apply some clear from an aerosol can after using the wet/dry sandpaper.
Rareair is offline   Reply With Quote
Old 03-07-2008, 05:43 AM   #2
Thanks for the tips. I'll see if I can polish them up a bit, though I'm not sure if I'll have much luck... it looks like all of the color is gone.
barkdog is offline   Reply With Quote
Old 03-07-2008, 02:29 PM   #3
Here are the before and after pics of my sanding/painting w/clearcoat method. I think I used 1000 grit.
shaman1204 is offline   Reply With Quote
Old 03-08-2008, 11:00 AM   #4
The one crest is missing red in a couple of spots. A little hobby paint and a steady hand does wonders to touch those up before clear coat. 1000 grit is too harsh, as well. Automotive supply stores carry #2000 or #2500 grit. I also would have only CC the crest, not the whole center cap.
That said (and nobody asked), they still look better than before.
Old 03-09-2008, 01:05 PM   #5
If they were for my summer rims I prob would have painted the missing red and just CC the crests, but they are for my winter rims/tires so I didn't feel like doing all the prep.
I didn't feel the 1000 was too harsh, it actually took a lot of elbow grease to get the white discolored spots out of the factory finish.
