Old 03-04-2008, 05:46 AM   #1
15W-50 vs 10W-30 which should I use?
Which Engine Oil should I use? I live in New Orleans.....
According to
http://www.986faq.com/2-0/default.asp#011
"10W-30 For areas where continuous ambient temperatures get below 50°F/10°C for significant periods of time but remain above 32°F/10°C most of the time.
15W-50 For areas where continuous ambient temperatures stay above 50°F/10°C most of the time."
joshua6060 is offline   Reply With Quote
Old 03-04-2008, 05:58 AM   #2
Brucelee's Avatar
According to
Refer to your owners manual. Generally, the manual recommends Mobil 1 -W-40, not the weights you refer to.
However, some folks in wamer climates use M1 15W-50 in summer, which USED to be the oil that Porsche specd.
I am reasonalby usre that 10W-30 has never been recommended by Porsche for a Box.
be sure to use a quality synthetic.
Rich Belloff
Old 03-04-2008, 06:05 AM   #3
bmussatti
Posts: n/a
If you want to use a 50 weight oil, the only Porsche approved one is Mobil 1 5W50. Unfortunately, this oil is not being sold in the USA. You can find it in Canada.
I might try this oil in late 2008.
You will be well served by 0W40 Mobil 1
Old 03-04-2008, 06:06 AM   #4
gcb
+1
0w-40
gcb is offline   Reply With Quote
Old 03-04-2008, 08:49 AM   #5
Hello.
I've already switch to 5W50. It's on the Porsche approved oil list for Boxster.
Take a look at this renntech post.
5w50 renntech post
frederic is offline   Reply With Quote
Old 03-04-2008, 08:58 AM   #6
What about a Mobile 1 Oil that is available in the United States?
Old 03-04-2008, 09:05 AM   #7
Mobil 1 0W-40, as others have mentioned already. The approved list also has a Mobil 1 5w-40, but I've never seen it available in the Boston-area stores. There are no xW-30 oils listed.
Regards,
paul...
paulv is offline   Reply With Quote
Old 03-04-2008, 02:18 PM   #8
+1
0w40
blueillusion97 is offline   Reply With Quote
Old 03-04-2008, 02:53 PM   #9
When the dealer changed the oil, they put in M1 0w-40.
Jason
jderiansf is offline   Reply With Quote
