Old 02-25-2008, 03:22 PM   #1
Custom Exhaust causing engine light to go off?
Hey! So im starting to believe that the Engine Check Light has been caused by my custom magnaflow exhaust. Anyone know if this can be true? if so anyway i can turn it off? I never touched the cats, only the mufflers. Thanks
Whats a Porsche?
2000 Porsche Boxster
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Custom Dual Magnaflow Exhaust
Custom Rear Diffuser
http://img255.imageshack.us/img255/6...umpic23bg5.gif
Where's my car? is offline   Reply With Quote
Old 02-25-2008, 03:56 PM   #2
i doubt its from the Exhaust, go get it scanned and see what the codes are.
06 Cayman S
07 RR HSE
Blkboxster is offline   Reply With Quote
Old 02-25-2008, 04:17 PM   #3
+1 on not the exhuast, Check your codes first then lets us know what it says.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 02-25-2008, 08:03 PM   #4
What does your custom exhaust consist of? If cat back only then it should not affect CEL.
did you recently refuel your car? many CEL lights is triggered by the gas cap not being put back on tight enough otherwise get the fault code read and go from there.
boxs2000 is offline   Reply With Quote
Old 02-25-2008, 09:36 PM   #5
Im going to go to Autozone and get it checked probably on Wednesday so ill get back to you guys with the code. THANKS!!
Whats a Porsche?
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Old 02-29-2008, 04:02 PM   #6
Dang Four Codes!!!
WOW i got it checked with the obII sensor it came out with four codes
Here they are:
p1126
p1128
p1130
p1133
CAN ANYONE HELP! THANKS !!
Whats a Porsche?
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
Old 02-29-2008, 04:54 PM   #7
p1128 and p1130 are O2 Sensor codes if I remember right, just google the others but I think they are also o2 sensor. Check to make sure they are all hooked up, I doubt they would all crap out simultaneously.
Also, you can get a good cheapo OBDII reader from Harbor Freight for $50, worth it!
Cory - Dallas, TX - 2001 "S"
http://filebox.vt.edu/users/comarti4.../signature.jpg
VTCMart is offline   Reply With Quote
Old 03-01-2008, 03:11 PM   #8
Don't know what year you have but for me the 1128 and 1130 were vacuum leak codes that I think were related to a bad oil filler tube. I have a 2001 base model.
shaman1204 is offline   Reply With Quote
Old 03-02-2008, 11:57 AM   #9
Boxster CEL Codes
Looks like most are 02 sensor running rich codes.
Old 03-03-2008, 03:37 PM   #10
Exhaust
I got a custom MagnaFlow Exhaust, so do you think the back pressure is causing the o2 sensors to read errors???
Whats a Porsche?
Litronics
Evo Intake
Chrome Front Grill
18" Turbo Twists
