Old 01-30-2008, 04:36 PM   #1
Durametric Update
There is a new update available for the Durametric software- with more to follow.
Here's what they changed/added:
Major update please report bugs, as there has been many changes.
We also have more features and updates in progress that will be release over the next few weeks.
* Software can now startup and run without the cable plugged in (demo mode)
* Universal DME Identification no longer need to select version of motronic
* Universal ABS/PSM identification no longer need to select verion of ABS
* New Control module support PDAS 1989-1994 Carrera 4 AWD/ABS system
o Read fault codes
o Clear Fault Codes
o ECU Identification
o Drive Links (Brake Bleeding, Transvese Lock activation)
* Cayenne 2003-2004
o Park Assist
o Tire pressure monitoring system (TPMS/RDK)
o Driver seat memory
o Passenger seat memory
o Trailer hitch
o ECU information on all cayenne modules
o Expanded fault code status data on all fault codes
* ABS 5.0 ECU information
* Airbag B01 ECU information
* Airbag B02 ECU information
* Tiptronic G01 ECU informaiton
* Motronic 2.1 ECU information, Actual Values
* Motronic 5.2 ECU information, Actual Values
* 997 Turbo DME ECU information (with Over-rev data)
* Updated PSM fault code data
* Motronic MS 3.1 DME 996/997 CUP cars ECU read and clear codes
* Improved installer
* Support for new diagnostic interface
Bug fixes
* Fixed problems clearing codes when PSM has more then 5 faults
* Fixed drive links on Motronic 5.2.2
derb is offline   Reply With Quote
Old 01-31-2008, 02:53 AM   #2
Does anyone know when a new download will be ready? Ed
cvhs18472 is offline   Reply With Quote
Old 02-18-2008, 02:52 PM   #3
Glad to hear there are new updates....for a month or two there i was getting worried that they are just seling their products but not working anymore...Great job....i wonder is durametric working on features that allow you to change various settings like VW software tools, for ex. time lights are on once the car is locked, alarm beps or not when activated....is it even possible on porsche?
blueillusion97 is offline   Reply With Quote
Old 02-18-2008, 04:15 PM   #4
can i turn on the on-board computer with it?
SinnerDC2 is offline   Reply With Quote
