Old 01-15-2008, 12:06 PM   #1
944 rims fit on my 2000 boxter
will a late model 1989 944 rims fit on my 2000 boxter
chriscornell007 is offline   Reply With Quote
Old 01-15-2008, 12:19 PM   #2
It's quite possible. They would definitely have to be late offset (87+), but even then you will want to ensure the widths are right.
However I could use stock 17" Boxster rims on my 944's, so I assume it would be safe the other way. Just be sure to check for caliper clearance.
life is participation in evolution
87 944 PRO44 racer. 01 986S (race build in progress), 93 968
schwank is offline   Reply With Quote
Old 01-15-2008, 01:13 PM   #3
HammerESQ's Avatar
I had stock 17" 986 wheels on my 951 for a while, but it was an '86 so I had to use a spacer. I guess it comes down to the year 944 wheels you are trying to use.
-Eric
HammerESQ is offline   Reply With Quote
Old 01-15-2008, 01:40 PM   #4
Check with cas951
He is a board member and has a 951 (88, iirc) and a boxster, so he should be able to tell you for sure.
bigb is offline   Reply With Quote
Old 01-15-2008, 06:17 PM   #5
From my experience, Boxster S wheels are direct fit into 87 and later 944's to include 968's. I've installed 17" and 18" wheels from Boxster's directly to late model 944's so it should work vice versa.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
