Old 12-07-2007, 05:03 PM   #1
blkboxster
Posts: n/a
Help!!!!!!!!!!!!
HEY. just got my wheels and tires and love them, but i have a question on lug nuts. i paid extra so the seller send me new ones, but i think there too small, how much are they supposed to stick out at the back of the rim. mine only stick out about .80 of a inch!! is that fine?
Old 12-07-2007, 05:11 PM   #2
1) The boxster came with lug BOLTS, not nuts. So, unless you converted your car to studs and nuts I am confused.
2) What do you mean they only "stick out about .80 of an inch"?
3) An SCCA type guideline I recall for wheel bolt/lug engagement is "13 turns" of the said nut/bolt. I have also head it said that you want engagement at least equal to the diameter of the bolt head/nut in question
So.. what was your question exactly? Don't be afraid to write out a nice description of your situation too
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 12-07-2007, 05:15 PM   #3
Racer, he means "Bolt" and he is saying that when he sticks the bolt through the rim, if he then turns the rim around to look at the inside... the Threads of the bolt only stick out 8/10 of an inch. He wants to makesure that isnt too short in length.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 12-07-2007, 05:18 PM   #4
blkboxster
Posts: n/a
EXACTLY!!!
Old 12-07-2007, 05:20 PM   #5
Now I think I get it... A pic would have helped an old timer like me I thought he was providing a measurement of the bolt with the wheel mounted on the car, not simply testing the bolt length through an un-mounted wheel..
Refer to part 2 of my original answer then
1978 911 SC (sold)
Old 12-07-2007, 05:26 PM   #6
I think the only way you can find out is by getting your original BOLT and seeing how car it sticks out behind your ORIGINAL rim... that should answer your question
Carlos J Cazares
Old 12-07-2007, 05:38 PM   #7
blkboxster
Posts: n/a
jUST did that and the original length is only a bit bigger. i will stick to the orginal just to be safe
