Old 11-28-2007, 11:51 AM   #1
HammerESQ's Avatar
Preventing IMS failure
As a new owner every time I hear a story about the IMS failing in one of our cars, I cringe and worry a little bit more.
So my question is, what (if anything) can we do to prevent an IMS failure in our cars?
Thanks,
Eric
HammerESQ is offline   Reply With Quote
Old 11-28-2007, 11:59 AM   #2
Best way to avoid the pain of IMS, try to drive the car 35k miles while still covered under warranty. Or get your own warranty if it's no longer covered (and the engine hasn't already had IMS failure). What year/model/mileage?
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 11-28-2007, 11:59 AM   #3
Brucelee's Avatar
Thanks,
Eric
It is a design failure. I am aware of nothing we can do to prevent it.
Rich Belloff
Old 11-28-2007, 12:03 PM   #4
Send a message via MSN to CJ_Boxster
I would say that using good oil and changing it within 10k mile intervals and getting those RPMs in the 5-6k range once in awhile helps.
I'd say that storing it for months or weeks,
Not letting the oil circulate atleast 30 seconds before driving off will bring you closer to an IMS failure.
I think that keeping those mechanical parts oiled and moving will reduce your chances of IMS failure. All in the name of reducing stress on the internal mechanical moving parts of your engine.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 11-28-2007, 01:51 PM   #5
Quote
"...getting those RPMs in the 5-6k range once in awhile helps."
Posted by CJ Boxster.
Not that I don't do that anyway, but I was curious. Why do you suppose that hitting 5-6K from time to time is a useful preventative against IMS failure?
Also, a question for anyone with an opinion on the matter: Is there a mileage beyond which you think IMS problems are unlikely? (I have a 2001 S with about 33,000 miles.)
Also (while I'm at it): Are IMS problems any more prevalent in a given engine (ie 2.5 vs 2.7 vs 3.2)?
Old 11-28-2007, 01:55 PM   #6
My solution was to buy an extended warranty today from Warranty Direct, and to plan on selling the car before it runs out. Oh, and then buying another Boxster and do the whole thing over again!
Paul B. Anders / Phoenix, AZ
1970 Porsche 914 / 2003 Porsche Boxster / 2009 Honda Fit Sport Auto
pbanders is offline   Reply With Quote
Old 11-28-2007, 02:38 PM   #7
tboyer's Avatar
Just enjoy your car! Why worry about something you can't prevent. Can't hurt to put a 3.2 on your Xmas list though, just in case
'06 Cayman 'S' - Sold (Sport Chrono, PASM, TPMS, 19' CAS Wheels, NAV)
'06 Cayenne - Sold
'01 Boxster 'S' - Sold
'00 Boxster - Sold
tboyer is offline   Reply With Quote
Old 11-28-2007, 02:38 PM   #8
There Is No Substitute.
rick3000's Avatar
The two big problems with Boxster's are RMS, and IMS. Once you pass about 25k miles your chances of either go down drastically but it still can occur.
Old 11-28-2007, 02:54 PM   #9
Send a message via AIM to YellowJacket
From the anecdotal evidence I've seen on IMS failure, it seems to be luck-of-the-draw more than anything else. I don't think there's much one can do to prevent it.
That being said, why are you so worried about it? Sure, it can fail, but every car seems to have a component that is prone to catastrophic failure. You want something really scary? The e36 BMWs (3 series from 92-98) had incredibly weak mounts where the rear subframe bolts to the unibody. They often ripped loose, dislodging the entire rear subframe. It was about as expensive as IMS failure, if I recall, but a lot more messy. And yet I drove one for years.
Enjoy your car. If it happens, it happens. Hopefully it won't.
YellowJacket is offline   Reply With Quote
