Old 11-26-2007, 03:10 PM   #1
blkboxster
Posts: n/a
Would these fit???
Size: 18x8 front/ 18x10 REAR
Offset: +48mm front/ +40MM REAR
and if they do what tire size would i need?
and would i need spacers?? and what size spacers
thanks
Old 11-26-2007, 03:23 PM   #2
Front tires in the 225-245 could work. 265-285 rears could work. Depends on the size of the spacers and if the car is lowered or not.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
Old 11-26-2007, 03:23 PM   #3
Do you have a link or brand name of the rims you are looking at for us to see. I could tell you just by looking at them because I think I have seen every wheel/rim combo out there for our cars. It does sound like it would fit with no spacers needed.
porsche986spyder is offline   Reply With Quote
Old 11-26-2007, 03:32 PM   #4
blkboxster
Posts: n/a
Free Image Hosting
what tire size?
Old 11-26-2007, 03:32 PM   #5
thanks
These will fit with no spacers needed. I'm running 275's or 285's in the rear. If your car is lowered you may get some rubbing on the inside of the fender wheel out back, you should have no issues in the front.
blackONblack is offline   Reply With Quote
Old 11-26-2007, 03:35 PM   #6
blkboxster
Posts: n/a
So if i want to find prices for the tire, i enter
275 18
what number goes in the middel?
Old 11-26-2007, 03:38 PM   #7
275 18
it should be 35.
insite
'99 Boxster
3.4L Conversion
Old 11-26-2007, 03:40 PM   #8
blkboxster
Posts: n/a
Originally Posted by insite
it should be 35.
thanks, just wondering how you found that out??
Old 11-26-2007, 03:43 PM   #9
I run an 18x10 ET40 rear, its a touch too far out (no clearance issues, but I'd like it to be about 5mm further inboard). Stock ride height you should have no problem. I run a 265/35-18
Patrick
Old 11-26-2007, 03:45 PM   #10
i have a set. your goal is to have tires that are just over 25" in diameter. you can check the tire rack's spec lists like this one to get the sizes:
http://www.tirerack.com/tires/Spec.jsp?make=BFGoodrich&model=g-Force+T%2FA+KDW+2&tirePageLocQty=
a 265/35 will actually be a better fit for the car. the 275/35 is a tad tall. i'd go with a 265/35 or a 285/30. what size are your fronts?
insite
'99 Boxster
3.4L Conversion
Old 11-26-2007, 03:49 PM   #11
blkboxster
Posts: n/a
fronts are
18x8 front
Old 11-26-2007, 04:13 PM   #12
blkboxster
Posts: n/a
what should my front tire size be??
thanks
Old 11-26-2007, 04:20 PM   #13
thanks
with those wheel sizes, i'd personally choose a 245/40 up front and a 265/35 in back. IMO this is the most neutral choice.
insite
'99 Boxster
3.4L Conversion
Old 11-28-2007, 01:34 PM   #14
blkboxster
Posts: n/a
thanks just bought the tires, rims should also be here soon
Old 11-28-2007, 04:57 PM   #15
When you get those wheels, let me know if there are any issues. Those are the same wheels I want to get but, even though it says they'll fit our cars...it also says their wheel fitment guide could be inaccurate.
yellowboxster01 is offline   Reply With Quote
Old 11-28-2007, 05:01 PM   #16
blkboxster
Posts: n/a
it should fit fine, a other meber BlackONblack has them and has no issues
Heres A PIC
http://www.pcars.us/garage.php?mode=view_gallery_item&type=garage_gallery&image_id=144
Old 11-29-2007, 05:06 AM   #17
Hey, thanks for the pic, I hadn't seen them on a Boxster yet. OMG, those taillights are hideous!!
Old 12-03-2007, 01:35 PM   #18
i chuckled when i read this because you are talking 3.5 mm or roughly 1/8 of an inch. That's tire wear after one DE or weekend ride through the twisties. If you can eyeball the difference, you are really good. i didn't calculate the effect on gearing, but it can't be much
mtch is offline   Reply With Quote
