Old 11-26-2007, 02:09 PM   #1
Send a message via MSN to CJ_Boxster
Very nice!
Just to be certain, Did you have the issue of not having enough adjustment to correct the "too much Negative camber" issue?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 11-26-2007, 02:26 PM   #2
My issue was too much negative camber, and too much inside toe.
I found out that the bolts will not work with our cars.
From what I have learned the adjustable toe arms will correct my toe and give me more room to correct my camber.
99 TWIN TURBO Boxster 175k+ miles
Growing up the car magazines said how amazing Porsches are. Was I brainwashed? Somehow...I doubt it.
http://www.pcars.us/albums/10641_porsche_cars.jpg
Gary in BR is offline   Reply With Quote
Old 11-26-2007, 02:32 PM   #3
Ah, my issue is too much negative on the drivers side front, even with the camber bolts pulled all the way to the outside I'm barely 0.01 degrees within acceptible range.
Carlos J Cazares
Old 11-26-2007, 02:36 PM   #4
Most coilovers have camber adjustment for the front. Its an expensive fix but it is a fix.
