Old 10-29-2007, 10:53 AM   #1
Exclamation Terrible rattling/clatter sound
Just started happening in the last month it is comming from the driver side rear I can hear it with the window up but it dosent sound too bad... when I put the window down it sounds terrible like a metalic valve clatter sound fresh oil change did nothing to improve it. This is a consistant noise at any speed in any gear however not at idle. I am really hoping it is not the valves, It is not suspension related possibly exhaust??
any ideas or experiences with this whould be greatly appreciated thanks
Jordan
also hot or cold has no effect on the noise
1999 boxster yellow
mechanical-
evo intake, chip, desnorkled, boxster s exhaust & brakes, lowered w/ eibach & M030 combo
cosmetic-
gt2 bumper w/evo lip, TA side skirts, factory yellow painted interior, 18" turbo twists wrapped in AVS sports, 6 pack mp3
jordan986 is offline   Reply With Quote
Old 10-29-2007, 11:00 AM   #2
bmussatti
Guest
Posts: n/a
Could be the cats. Or the heat shields on the cats.
Old 10-29-2007, 11:18 AM   #3
I've already had the heat shield issue this one seems different Its a fairly new $2000 exhaust setup the cats shouldnt be gone yet (I drive very spirited however I will look into that) thanks
1999 boxster yellow
mechanical-
cosmetic-
Old 10-30-2007, 04:55 AM   #4
Spark plugs
My mechanic told me that the spark plugs also cause a knocking type noise in the boxster when they come loose. They require a higher than normal torque...which I cant remember. But check those.
Chris
Dohertycm is offline   Reply With Quote
