Old 10-25-2007, 06:56 AM   #1
Adapter for cigarette lighter
Hi everyone,
I'm looking for an adapter to run my Garmin in a '01 Boxster (small USB connector). The one I used in my Z4 simply pops out by itself. I know the boxster lighter is European format (the Z4 obviously not) and shorter. Does anybody have a source for fitting adapters (in Los Angeles)?
Thanks in advance for your help!
miles is offline   Reply With Quote
Old 10-25-2007, 07:16 AM   #2
Miles,
Hope this helps :
http://www.renntech.org/forums/index.php?act=Print&client=printer&f=24&t=16263
Nick
http://i146.photobucket.com/albums/r...s/DSC03717.jpg
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
NickCats is offline   Reply With Quote
Old 10-25-2007, 07:21 AM   #3
There Is No Substitute.
rick3000's Avatar
You can replace the entire cigarette lighter with the US version which is deeper for about $12 check out cb-racing.com.
Old 10-25-2007, 07:24 AM   #4
Thanks, Rick ! I was looking everywhere for that site :
http://www.cb-racing.com/boxster_cig_socket.html
Nick
1999 986 ( Black )
Old 10-25-2007, 08:36 AM   #5
Thanks so much, Rick!
Old 10-25-2007, 08:50 AM   #6
ChrisZang's Avatar
When I installed my Garmin I chose a "cleaner" install:
I didn't want a cable to dangle from the cigarette lighter plug all the time, so I decided to conceal as much as possible.
So I got a plug for cigarette lighters at RadioShack and installed it inside (behind) the center console
I "stole" switched power from the radio and then routed the Garmin cable from inside the console to come out behind the instrument cluster.
in total about 4 hrs work time if you do it slow
Old 10-25-2007, 03:39 PM   #7
rick3000's Avatar
I did the same. After doing the OBC hack I felt comfortable taking the insturment cluster off, so I ran my GPS cable down under the instrument cluster behind the center console. If you check my registry page in my sig. there are more details there.
