Old 10-19-2007, 06:57 PM   #1
Hardtop Access Question?
Does anyone know the access to the metal strips on each side of the hardtop encased with rubber? Are they pried off on the exterior or need the headliner be deinstalled to access from underneath?
Looking to have my hardtop painted and wish to prepare for such as much as possible myself.
Thank you, in advance, for any info.
John
Reynard is offline   Reply With Quote
Old 10-19-2007, 07:17 PM   #2
There Is No Substitute.
rick3000's Avatar
I had to do this to adjust the top to fit against my windows better. It is relatively easy to do. Lay the town down upside-down, so the headliner is facing up. The at the top near the front end the rubber molding flips in, in a U shaped cap over the end. Flip it out then just lightly pull it out of the metal track. I only pulled it out half way so I am not sure if there are any problems pulling it out all the way. Then to get the rubber back in just push the back into the rail and then I used a flat head screwdriver to push the front back into the metal rail.
Also you can remove all the plastic, and probably the headliner if you want by lightly pulling up. The metal clips should pop out, and it is easier if you slide your hand under the plastic and pull directly around the clip.
Hope this helps!
