View Poll Results: What type of IMS Failure have you had?
No IMS Failure 50 87.72%
IMS - 2.5L 1 1.75%
IMS - 2.7L 1 1.75%
IMS - 3.2L 5 8.77%
Voters: 57. You may not vote on this poll
Old 09-28-2007, 04:26 AM   #1
Senior Member
Had an IMS Failure?
This is a quick poll of forum members.
rkwei is offline   Reply With Quote
Old 09-28-2007, 06:56 AM   #2
Brucelee's Avatar
My vote is for my neighbor's 04. She is not a member on the forum.
Rich Belloff
Old 09-28-2007, 07:26 AM   #3
I have an 2004 2.7... what mileage did hers happen around? Just got my car back from a RMS leak, and while it was in there I had a clutch disc put in...tech said it only had about 1-2k left on it Mine was done @ 30k...I don't know how the previous owner drove
2004 Boxster 2.7
Meridian Metallic/Graphite Grey
http://i181.photobucket.com/albums/x...s/2004_986.jpg
markab986 is offline   Reply With Quote
Old 09-28-2007, 07:59 AM   #4
Brucelee's Avatar
11K miles I believe
Rich Belloff
Old 09-28-2007, 08:55 AM   #5
Sorry for my ignorance here, but what is IMS?
Happy Motoring!... Tim’05
http://i153.photobucket.com/albums/s..._kill/Siga.jpg
Dr. Kill is offline   Reply With Quote
Old 09-28-2007, 09:42 AM   #6
Had mine in for the 15k service week before last and asked them to check the RMS (which I knew was in fact leaking). They replaced the RMS under warranty and also fixed an IMS leak. So it hadn't failed, but I guess might have been on the way there.
dmcutter is offline   Reply With Quote
Old 09-28-2007, 10:54 AM   #7
Brucelee's Avatar
Intermediate Shaft Failure. total engine melt down.
Rich Belloff
Old 09-28-2007, 11:11 AM   #8
Thanks - am thankful I haven't had to learn yet what that meant.
Old 09-28-2007, 12:44 PM   #9
To those very unfortunate souls who have had IMS failure or know somebody who had one, can you please post the following details:
-Corrective action taken
-Cost
-If out of warranty, successful PCNA support (Y/N, magnitude)
-Year
-Mileage
-2.5, 2.7, 3.2, 3.4, etc
-A sad venting story
JCL12 is offline   Reply With Quote
Old 09-28-2007, 02:13 PM   #10
It would be great if there was a way to change your vote if you get IMS failure in the future. Still, This is a good poll to have!
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 09-28-2007, 07:13 PM   #11
We should periodally open the poll and see what happens!
I wonder . . .
If the IMS issue is a type of systemic flaw that will eventually cause all boxsters to die. . . .
Or if the IMS failure will only affect a small % of M96 derived engines, regardless of lifespan. I just can't beleive that porsche (after all these years) has still failed to find the root cause of the failure and correct the problem. Same goes with the RMS - I assume 987's still leakey?
Old 09-28-2007, 07:57 PM   #12
Franco's Avatar
Thumbs down
Hi, Also are there any preventative measures that can be taken to avoid these 2 types of Failures.
The occurrence of these failures over a 10 year period is just unbelievable to me.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
Franco is offline   Reply With Quote
Old 09-29-2007, 07:36 AM   #13
Brucelee's Avatar
Smile
Minn Jim knows more about this than I do and has posted before so that you can do a search for the details.
In short,
We don't believe the design issue is resolved as there have been post 05 Boxes with IMS. Also, there is nothing that you can do to prevent this as the issue is design, not use.
I think this is correct.
Rich Belloff
Old 11-23-2007, 02:55 PM   #14
Guys
Check this site out for the cure to IMS issue these guys have really got it sorted http://www.autofarm.co.uk/engines/water_cooled/shaft_tech.
ikdavis is offline   Reply With Quote
Old 11-23-2007, 08:19 PM   #15
It appears that their fix pertains to the oil leak part of the problem. Oil leaks are one thing, that can be fixed (may not be cheap, but can be fixed). IMS failure will leave you a very heavy paperweight of an engine. It is my understanding that the previous (before 01) ran on a double bearing, and almost none of these fail. The 01 and newer run in a single bearing, and these are the motors that may fail. Last I knew there really was no cure for this, but it does seem that the motors that are predisposed to failure do so relatively early in life.
Patrick
