Old 08-23-2007, 09:48 AM   #1
Air scoops
A friend of mine is creating a prototype for making some sidescoops for the boxster and although in very rough initial stages I thought I'd post some pics to get some opinions and feedback.
They are similar to the Kokeln scoops but will be taller and the intake a bit narrower to give them a slimmer look. He is still toying with the idea of how to attach them but his initial idea was that they be kind of like caps instead of full replacements so that you would loosen your original scoops and then slide these over the back of the oem scoop and between the body then put the screw back in and they would be held in place by compression and maybe some adhesive at the bottom of the piece.
- ian
idheaton is offline   Reply With Quote
